Question about Coffee Makers & Espresso Machines
Oster Model #3305-33 It is taking a long time to brew, the unit is very very hot and we put in 12 cups of water but only 8 cups comes out (very strong coffee!). We think the water is evaporating and we have cleaned the machine. Thanks!
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
  • 19 Answers
SOURCE: Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
Posted on Jan 19, 2008
IrishDruid
  • 2712 Answers
SOURCE: oster coffee maker
Looks like you will have to contact Oster directly. I am unable to find replacement pots asa standalone for sale. You can contact them here:
http://www.oster.ca/consumerservice.aspx?content=contact
Or you can call them at (800) 334-0759
Canadian Residents: (800) 667-8623
Posted on May 19, 2008
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Posted on Apr 03, 2009
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
If I pour in 8 cups of water the coffee pot will only make 6 cups
There is a secret compartment they do not tell you about when you buy it. The water is stored there in case of a drought so you can at least have a glass of water...
May 24, 2010 | Oster HDX23 12-Cup Coffee Maker
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I've lost my manual for the Oster coffee maker model 3314-33 and the red "Clean" button keeps flashing after the coffee has brewed. Where can I download a manual so I can figure out how to fix this...
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Aug 15, 2009 | Oster HDX23 12-Cup Coffee Maker
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Slow brew time / water disappears?
I have this problem with a 4 cup model. 4 cups in, 2 cups out. I cleaned it twice with vinegar (with a filter in place). The first time didn't seem to help, but the second time I got about 2.5 cups out, along with a bunch of old grounds that I think had been sucked into the pump. Ran water through it twice, and now it gets to about 3 cups.
I think the problem is just that the pump is clogged with grounds. If vinegar makes yours worse my guess is that a big piece got dislodged and is now blocking the tube. More vinegar might help.
May 20, 2008 | Mr. Coffee ISX23
Coffee Makers & Espresso Machines Logo
380 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
