Question about Copystar CS-1500 Copier
J11 error code
How to fix J11 error code
Canon inmage class mf3010 E202 service error
E202 CIS Unit home position detection error / homeward reading position error When the same error repeatedly occurs although the power is turned OFF and then ON for several times, execute the following remedies.
(1) Check the connection between the Main Controller PCB and the CIS Unit. (J2)
(2) Replace CIS Unit.
(3) Check the connection between the Main Controller PCB and the Reader Motor (M3). (J11)
(4) Replace the Reader Motor (M3).
(5) Replace the Main Controller PCB.
Mar 27, 2015 | Canon Office Equipment & Supplies
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
THE MACHINE INDICATE J11 WHAT IS THE PROBLEM
j11 indicates that the paper is not being fed from the paper cassette 2.
This can be caused by incorrectly loaded/thick paper. Cassette not correctly adjusted.
Paper feed rollers need to be cleaned or replaced. Blockage or parts failure.
Mar 24, 2014 | Kyocera Copystar CS-1635 Copier
Chery j11
What To Do When : WIN appears on the dashboard of a Chery J11 SUV : Easy fix just a push of a button...Push the little button with the snowflake on it, it is to the left of the gear shift. This button allows the car to accelerate in 2nd gear in snow or icy conditions. It is also only to be used for this purpose any other use of this switch will burn the gear box out as the internal temperature will become critical fast.
May 29, 2013 | Cars & Trucks
How to reset chery service light model j11
how can i reset the service light on 2011 j11 2.0 chery
Mar 26, 2013 | 2009 Nissan Altima
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Need driver satellite j11 driver
download here /laptops-notebooks-drivers.com/tag/satellite-j11-240c4
Jun 10, 2009 | Toshiba Computers & Internet
Driver sound laptop toshiba satellite j11
Hi Friend,
Kindly copy and paste the Link u can collect your sound driver
link is http://drivers.softpedia.com/progDownload/Toshiba-Satellite-A215-S7472-Realtek-Audio-Driver-6-0-1-5433-Logo-Download-41853.html
Once u Copy paste the link u get the page and then click the download_bullet.gifExternal Mirror 1 u will get the Download of the Sound Driver
Regards,
Ayyasam
Jun 03, 2009 | Toshiba Satellite M35X-S114 Notebook
Copystar CS-1500 Copier Logo
125 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
