Question about Epson Perfection V700 PHOTO Flatbed Scanner
Some of the 35mm colored slides we scan are being significantly "cropped" by the scanner leaving a black band on the side(s) or top. It seems to do this on a random basis. We have tried doing one slide at a time, moving the slide to different position in the holder, turning them differently, etc.
Look at the illustration on the slide scanner itself . It does not take into consideration the orientation used of the picture. You have to lay all slides horizontal parallel to the side of the scanner, or Perpendicular to the word "Epson" on the cover of the scanner. I thought it was trying to be to smart, but it's reall just a dumb issue. Hope this helps...
Posted on Jan 12, 2013
I am having exactly the same problem. Any solution yet?
Posted on Aug 12, 2010
I am having problems scanning 35mm slides, I seem
you have chosen normal preview
1. change it to thumbnail preview
2. or click on "All" button in normal preview
so you would scan multiple negatives.
increase your dpi setting or your target area or both
I am also scanning color negatives at 3600dpi and 48bit. file is large but quality is very very good...
Mehboob Riaz, SIPA, Lahore-Pakistan
Jul 08, 2010 | Epson Perfection V700 PHOTO Flatbed...
Canon 8800f - black space - positive slide
There is actually an issu with those series of scanners. Did you upgrade your driver ont the canon website? I had same issue, never get rid of it and change to Epson. I did scan 50 000 of slides in my career. I found at some point that some of bigger window slide where not recogninze while smaller window ones where almost okay. Try changing the sides of the slide in the holder to get better cropping in some situations... Let us know!
Oct 10, 2009 | Office Equipment & Supplies
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Getting true color on slide scans
Make sure you have the emulsion (image) side of the slide towards the scanner sensor. Some scanners have a special setting for film still in slide holders to correct for focus. You may need a photo edit program to help with color and density. I find no difference from 35mm to split 5x7s altho bigger is always better.
Jul 03, 2009 | Nikon LS-9000 Film Scanner
Slide scanning with Epson Perfection 2450
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
Dec 08, 2008 | Epson Perfection 2450 Photo Flatbed...
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Unwanted cropping of some 35mm slides using CanoScan 8400F
Turn off the thumbnails view and you can manually set the cropping box.
Nov 29, 2007 | Canon CanoScan 8400F Film Scanner
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Epson Perfection V700 PHOTO Flatbed Scanner Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
