Question about Craftsman 25cc Gas Line Trimmer
Trimmer will not stay running without the choke on. It will still run but not well and it will not let you throttle up. Is it an adjustment on the carb? The other problem is I dont have the owners manual to identify the two adjustment screws on the top of the motor.
  • 54 Answers
You have fuel flow problem obviously. One of the screws is idle adjustment, easily identified by SLOWLY turning it in or out for change in rpm, the other is your high speed jet, turning it in or out while trigger is at full throttle to get max rpm and instant response from idle. Something else to check might be for an air leak in the fuel line, loose connection etc. Check the primer bulb area very well including the bulb itself. Hope this helps.
Posted on Apr 26, 2010
I own a Husqvarna 128LD. My trimmer works on full choke, half choke, and when in the run position...it runs...but when the trigger is on balls to the wall throttle, it goes dead. What is my next move?
The next step is to richen the fuel mixture on the H screw on the carb, there is a special tool required to turn the adjuster screws because they have a splinr rather than a screw driver slot, the tool is part np. 530035560 unscrew tthe H screw 1/4 turn anti clockwise.
Aug 07, 2012 | Garden
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
I have a Ryobi trimmer and when I start it will not stay on
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Mar 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25cc Gas Line Trimmer Logo
494 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
