I have an RCA RTD315W and it's new. At times the sound will randomly cut in and out and i don't know why. Why is this and how do i fix it?
  • susanbea57 Apr 26, 2010
    I think it has something to do with the cables, and possibly the HDMI Output. The cutting in & out was while we were watching a blue ray DVD in a connected blue-ray player.
  • 19,396 Answers
Hi.
Check connection cables and connected devices, like DVD, receiver box etc.
If a connected device is defective, or if connection cable is bad, this can cause the TV audio going on and off randomly.
If you are using an home theater system, check audio cable to system and cables from system to speaker.
If possible test the TV using only an external aerial connected to the back of the TV, and the TV internal speakers. If the problem still occurs, then the TV is faulty.
Also try plugging in and out headphones (if headphones connector is present). Try to understand if you get same problem using headphones, this will point at a common fault concerning internal speakers connectors.
In that case call RCA at the number listed on the owners manual , if the TV is new, then it will be replaced or repaired under limited warranty terms. Before agreeing the repair RCA will ask you to perform a test similar to the one I told you (test TV stand alone).
Posted on Apr 26, 2010
  • Ginko
    Ginko Apr 26, 2010
    Hi.
    As said you need to isolate the problem, finding out if the problem is wires, TV or connected device. To this purpose just guessing is not enough.
    Test if you get the problem with TV stand alone.
    Test connecting the BRD player on a different cable (eg use AV cables for testing).
    If the problem is the cable, replace it.
    If the problem is either device, contact the manufacturer and have the device fixed under warranty.
    There is no setting that can cause audio coming and going randomly, one of the three parts is faulty.
    Regards.
I have an RCA rtd315w home theater system and I am trying to connect my xbox to it so it will play the sound. I have my xbox connected to my tv through a component HD cable. How can I get the xbox sounds...
run yellow cable from xbox to TV vide input for picture!, now run the red/white cables to AUX ibput on the RCA and push function till you see aux and poof, you got Video on the tV and audio from the surround sound.
Sep 05, 2013 | RCA Rtd315w Dvd Home Theater System...
Rtd315w wont do any thing,i plug it in and the blue lite comes on push power or open lite goes off and nothing works no display and sometimes a taping sound from speaker/fuse seems ok
If its under the 1 year warranty call 1800 252 6123 and they will do it no charge with any type proof of purchase, if over the 1 year they charge 45.00 maximum! and will repair it or replace it if it cant be fixed, then ship it back with a 1 year warranty, takes 4 weeks aproximately
Sep 21, 2012 | RCA Rtd315w Dvd Home Theater System...
Codes for RCA RTD315
if you need a remote for the rtd315w you can use the RCA D771. Put the code in manually in the AUX 1. Use the codes from the audio system section of the manual under RCA and RCA/DIxxxx. I don't remember which code, but it gave me on/off, volume control, and DVD menu navigation (on the guide and goback buttons).
Dec 22, 2011 | Televison & Video
RCA RTD315W
my home theater RTD315W fails WELLCOME
May 13, 2010 | RCA RTD315 Theater System
I just bought an rca surround sound rtd315w - mp3 won't work
You must select that input with the RCA surround sound
Apr 20, 2010 | Televison & Video
No code for my RCA DVD HTS on my Philips Universal Remote.
does anyone have a fix for this problem, i have essentially the same problem, my remote is the phillips sru5107/27
Feb 28, 2010 | RCA RTD300 System
RCA Home Theater model RTD315W
  • You need to change your audio settings in your TVs audio menu. Sounds like it is set to play only external source when connected, There will be a setting for all speakers to play, including TV's. Have your TV's volume up just a hair when changing your settings and you will be able to hear when it changes to what you want.
Jan 27, 2010 | RCA Audio Players & Recorders
I have a RCA RTD315W home theater system. Are the speakers suppose to work with regular TV? Or does it just work in DVD mode? If it is suppose to work with the TV do i need a HDMI cord to make it work?
I have a RCA DVD Home Theater System, RTD315W. The "On/Standby" light is on (displaying a blue light), no other features are working. When I press a feature buttom, the blue light goes out. System just isn't working. System haven't been exposed to water/moisture. What the problem?
Dec 30, 2009 | RCA RTD315 Theater System
Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Apr 18, 2009 | RCA RT2500 System
 Grubhead
Grubhead
