Question about SanDisk Memory Media
Can't format 2Gb Extreme III SD card in Canon G9 camera
Because the camera simply reports "Memory card error".
Other identical cards work ok in camera.
This card has been used for Vista ReadyBoost but is otherwise new and unused in the camera.
Tried formatting in Vista but no change.
Sandisk RescuePro software does not seem to have a format option - odd.
My camera is Canon Power Shot SD750. I bought a new 2GB card. I believe that I formatted it on the camera - I chose "format" and followed instructions from the camera itself. Then, I try to upload onto HP Image software, but it tells me that the "status from E:\" is "No media" even though I have taken pictures without problems. When I try to look in E:\ - the computer tells me it's not formatted and to chose to format it in FAT or FAT32, but I'll loose all images if I do that. I don't understand the problem.
    Brigadier General:
  • 6,966 Answers
Hi LeslieWilson ,
If I may add to IB4G2008 and Jaime867.....
I think you are torn between a rock and a hard place and that is your concern, either way you loose.
What I would suggest:
1. Run a file recovery program and hopefully recover what ever image files could still be recovered from the memory card. This should be done using a memory card reader and the memory in question. I have had good results using Get Data Back for FAT expect other comparable software to be as effective. The demo/freeware version would only allow few file retrieval at a time.
2. Successful on # 1 or not, the next step would be to format the memory card. I would suggest using first HP Drive Key Boot Utility as I have had several issues with Windows built-in format command for external storage (including memory cards). Thereafter the built-in format feature of the camera may be used if ever required.
3. Run Flobo HDDBadSectorRepair or something similar if there are any bad sectors.
4. If any of the above or the suggestions of the others will not work, you may want to consider simply replacing it as it is then suspect and you of course wouldn't want to entrust saving any images thereafter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
  • Louie  Role
    Louie Role Mar 25, 2008
    Hi again,
    Any development with your memory card?
  • 2,326 Answers
Try to assign a different letter to the new device by right click on my computer > left click on manage > double click on disk management > right click on the "E" left click on change drive letters and paths. At this point assign letter "Z" for example, that should work.
    Genius:
  • 3,587 Answers
Ahah..well..then perhaps your canon is Vista unfriendly? have we checked that option yet?
i will look into that..
2 Suggested Answers
samkong
  • 106 Answers
SOURCE: Can't format 2Gb Extreme III SD card in Canon G9 camera
Did you try formating with the Camera? Before that, Try formating with Windows Disk manager, then format with the camera, It will solve the problem.
Posted on Nov 02, 2007
Format a new sd memory card ?
Memory cards need to be formatted before use. Please refer to your camera manual for instructions.
Your camera may not work with 8GB SDHC cards, only with SD cards 2GB or smaller. Such cameras will report a card error and/or request formatting if you try to use an SDHC card.
If you require further assistance, please add a comment to this question and specify the model of your Kodak EasyShare camera.
Sep 13, 2014 | Kodak EasyShare Cameras
I have a canon powershot a520 camera it it says memory card error only when I use the 8 gb memory card?
The A520 works with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not specifically designed to use them. You need to use SD cards, 2GB and smaller.
Oct 10, 2012 | Cameras
Can a 16 mb sd card of a canon zr600 be upgraded to 2gb?
Sure. Simply use a larger card. The ZR600 will work with any SD card. Be careful to get an SD card and not an SDHC card. SD cards go up to 2GB (2000MB) in size. SDHC cards look identical but start at 4GB but will not work with this camera.
Apr 10, 2012 | Canon ZR600 Mini DV Digital Camcorder
I bought a new memory card for my Canon Power Shot SD 400 Digital Elph, but it has an error message that comes up. When I scrolled through the Menu to format the card, the format selection is grey and...
Your older camera can only work with 2GB or smaller standard SD cards. It is not capable of recognizing the newer format 4GB or higher SDHC cards. Fortunately, old format 2GB SD cards are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them.
Sep 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Asking what to do?
8 GB is more than your A540 can handle. You can check with Canon, but I'm pretty sure that the max that your camera will understand is 2GB. Additionally, your 8GB card is most assuredly an SDHC card and not a standard SD card. Your A540 also does not understand SDHC format. The max card that you should buy for that model camera would be a 2GB standard SD card. These are very inexpensive these days and run about $6, shipping included:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=2gb+sd+card
Jan 20, 2009 | Canon PowerShot A540 Digital Camera
bad card trash it and get new one changeing formats will cause errors most camera's use their own format if u cange it from one to the other so many time it burns card out
Dec 28, 2008 | SanDisk Memory Media
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
It says the memory card needs formatting but when i go to format it this error occurs, FILESYS ERROR e00100
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
Aug 14, 2008 | Kodak EasyShare Z612 Digital Camera
Error message on san disk sd card
You may have answered your own question. There is a good chance that your memory card has reached the end of its life. You might try reformatting the card with the computer and then do the format in the camera. This has worked for me before.
Jul 18, 2008 | Cameras
Nov 01, 2007 | SanDisk Memory Media
Electronics - Others Logo
131 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
