Question about Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
Can't send instruments (live or recordings) to the tape output.. (does not see signal in Cubasis)
  • Behringer Master
  • 5,603 Answers
Anything you hear in the mains SHOULD come out the "tape out" jacks UNLESS you have the "tape to mains" button pressed in. (That is for driving the mains from tape or CD) Remember these are line level signals.
Not sure about Cybasis? Is that Cubase software? If this is through a USB port, Cubase, if that is what you have, has to be set up to receive the signals onto tracks. There are a lot of things to NOT get set right with this program... Always use a set of headphones to verify that signals are coming through the mixer.
Posted on Apr 28, 2010
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Monitoring vocals and cd/tape
Here is a link for the manual, can't download it but you can read it online.THESE words are written on page 9 of the manual," If you are recording a signal via the TAPE OUTPUT and wish to listen to this simultaneously via the CD/TAPE INPUT, do not use the CD/TAPE TO MIX switch. Doing this would create a feedback loop, since the signal would be routed, via the main mix, back to tape via the TAPE OUTPUT. To monitor the CD/TAPE INPUT, use the CD/TAPE TO CTRL switch to assign the tape signal to the monitor(s) or headphones. This will avoid the tape signal being routed to the TAPE OUTPUT."
It also says this under that,"If you want to monitor only the efects signal in your headphones or monitor speaker(s), press the FX TO CTRL switch. Now the signal of the efects processor can be monitored alone, and the main mix andnor CDntape signal is no longer present on the phone and control room outputs."
The link for manual is below
http://www.manualowl.com/swfviewer/viewer.php?ViewModeToolsVisible=true&FitWidthOnLoad=true&Scale=0.6&ZoomToolsVisible=true&ZoomTransition=easeOut&localeChain=en_US&FullScreenAsMaxWindow=true&SwfFile=%2Fmanualswf.php%3Fid%3D333864%26manual_type%3Dproduct%26d%3D2501bc0bd655f7f874a872da268a7ed6&ZoomTime=0.5&NavToolsVisible=true&ProgressiveLoading=true&ZoomInterval=0.1&CursorToolsVisible=true&FitPageOnLoad=false&SearchToolsVisible=true
Feb 28, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
100 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
