2006 Toyota Sienna with an ADVENT DVD
2006 Toyota Sienna with an ADVENT overhead DVD player...will not eject DVD...I tried the paperclip idea (no emergency eject hole on this model )and I also tried tweezers to pull it out (not working).
Any other suggestions????
    Problem Solver:
  • 7 Answers
Well, if its crammed in there from kids shoving stuff in there as kids will tend to do sometimes, then i am sorry to say, you most likely will need to get a new player. Cause general when something is jammed into disc slot, other components that are vital to operation have been compromised. But on the other hand. If it was working and operating fine one minute, and the next it simply just wouldn't eject. Your problem is one of the 2. Is the player making any noise as if it is trying to eject the disc but will not, and can you still at least play the disc and watch it since its already in there? If so. It sounds like you have a bad gear or a little spring that has popped that engages the gear to make the mechanism for disc ejection impossible. Or the main drive belt has dried and broke. Take it to a local tech. 2nd. If its not making any noise when eject button is pressed. The button itself might be bad. Try the remote controls eject button. If it has one, that might eject the disc. Hope this helps. And in tghe future, no paper clip tricks okay. Only damage can occure with that method. good luck,
Posted on Apr 26, 2010
Overhead DVD player in 2008 Toyota Sienna does not show the picture. Sound works.
Hello, I hope this helps. If no change then you probably have a hardware/ wiring issue and the dvd player may need to come out. Please advise
1. Confirm the DVD RSE system is inoperative. (blank screen) 2. For vehicles with Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Press the INFO switch on the navigation unit. B. Press the "Screen Setting" touch button on the navigation display. C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display. D. Press the DVD switch on the RSE system (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 3. For vehicles without Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Push the Audio Control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "REAR LOCK" is shown on the screen. B. Turn the Audio Control knob so the display says "OFF" next to "REAR LOCK". C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 4. If the above procedure resolves the concern, explain the system operation to the customer.This procedure is described in the Audio/Video" section of the vehicle Owner's Manual. 5. If the above procedure does NOT resolve the concern, perform RSE diagnosis using the Technical Information System (TIS), 2006 model year applicable vehicle Repair Manual.
Jun 29, 2015 | 2008 Toyota Sienna
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
CD stuck in DVD Player of Toyota Sienna 2006
You will have to mechanically overhaul the DVD player out and get you unstuck the CD. A example video of 2001 Chrysler .
Apr 03, 2015 | 2006 Toyota Sienna
How do I get a dvd out? the eject button wont eject the disc..
Ah! This is an easy fix! All you need is a bigger sized paperclip or something of that sort. You bend out one piece of the paperclip (a 90? angle) and push the paperclip Straight in the little tiny hole you can see on the disc door or next to the door. It will manually turn the gears to roll out the door.
Jan 26, 2015 | Audiovox ADV45 - 12.1 LCD Overhead Monitor...
What is the brand name of 2007 Toyota sienna Overhead dvd player
Codes are stored in your universal remote. You can use its "code search" feature to seek a code that will control the Toyota DVD player.
Dec 01, 2014 | 2007 Toyota Sienna XLE
My 2006 toyota sienna DVD player won't shut off
Engine room Junction Box - on left side of Engine Compartment (Drivers side in USA) - Fuse RAD 1 (20A), Fuse RAD 3 (30A) - there is another fuse that goes to your ECU, it works with the radio, but you won't need to pull it. In case you do - it is Fuse ECU-B (10A)
Oct 14, 2013 | Cars & Trucks
2008 Toyota Sienna, overhead DVD player will not power on
It would definitely have a fuse somewhere. If you have the owner's manual, that would show you where it is. It may be in the power distribution center, or block, that is under the hood, and close to the battery. Some vehicles have more than one of these small boxes in the engine bay that hold large and small fuses and relays. And then there would be a fuse panel somewhere inside the car, usually on the driver's side under the dash. Maybe behind the kick panel near the floor (where your left foot rests when driving).
Good luck. If you can't find the fuse, ask the dealer where it would be.
Feb 24, 2012 | 2006 Toyota Sienna
Advent DVD player in car won't eject DVD
Get hemastats or a thin pair of tweezers and have at it.
Mar 12, 2009 | Sony MV-900SDS Car DVD Player
Dvd stuck in advent 10" dvd player in 2006 sienna.will play only so far but will not eject.
Sienna Minivan with a DVD entertainment system - rule nr 1 - Recorded DVDs would play but not eject, and then jam the system. It will require disassembly of the housing to reset power to eject.
Oct 04, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
591 people viewed this question
Top Televison & Video Experts
Electro Med Services...
