Question about Samsung CLP-510 Laser Printer
If I put paper into the tray that opens on the long side of the printer it does not print. only from the smaller paper tray on the rear of the machine
    Scholar:
  • 67 Answers
Check your printer driver in Printers & Faxes under "Preferences" and "Properties" for this printer. See if you have the small or manual feed tray specified aas default. You need to make the tray you want the default tray for the driver, or you will have to tell each print job to go to that tray before you press OK on print command dialog screen.
Posted on Apr 26, 2010
Testimonial: "quick and accurate. Problem solved"
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Hi Where do I load the paper in my Canon MX310?
    The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
    Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
    Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
    I hope this helps.
    Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
    I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
    The printer will not print as long as the paper output tray is closed.
    1. Open the Paper Output Tray (2).
      Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
    2. Open the Output Tray Extension (3).
      Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
    3. Adjust the position of the Paper Thickness Lever (4).
      Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
    Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
    How to print with the legal paper?
    follw the given step and check-
    1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
    2-Go to the printer and take out the paper tray. Remove the letter size paper.
    3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
    4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
    5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
    6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
    7-Print a test page.
    Thanks,
    Dec 03, 2009 | Brother HL-2040 Laser Printer
    HP 6540 Lights flashing can't print
    This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
    The printer might be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of the printer.
    There might be a paper jam
    1. Press the Resume button. If the paper jam does not clear, then go to the next step.
    2. Push the two latch handles on the rear access door toward each other, and then remove the door.
    3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
    4. Replace the rear access door.
    5. Press the Resume button.
    If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
    1. Turn off the printer.
    2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
    3. Remove any paper inside the printer.
    4. Open the duplexer.
    5. Remove any paper from inside the duplexer.
    6. Close the duplexer, and then re-attach the duplexer to the printer.
    If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
    2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
    3. Remove any paper that is inside the printer.
    4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
    5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
    1. Tilt the Small Paper Tray
    2. Open the lower door
    6. Remove any paper that is inside the accessory.
    7. Close the accessory, and then secure the back lever to close the accessory.
    8. Re-attach the accessory to the printer.
    Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
    Won't print...sends a message that the papaer is out
    Had exactly the same problem. The solution was a piece of scotch tape. Open the small paper tray, and position the paper guide (the rear one, not the side one) so that you can put your paper stack down with a little bit of looseness, then tape it down so it can't slide back and forth anymore. Now put the paper back in. This worked like a charm for me. Turns out the rear guide was a little too loose so that everytime the paper tray got sucked in, it would push the whole paper stack backward and then the rollers couldn't find the top sheet to feed into the printer.
    Sep 15, 2009 | HP Photosmart D7260 Printer
    Can't print DL envelopes on a Pixma iP4600
    Hi ...
    If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
    Prepare the printer:
    1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
    2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
    3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
    4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
      * Figure 1
    5. Load the envelope.
      1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
      2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
        * Figure 2
      3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
        * Figure 3
        Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
    Preparing Envelopes to Load:
    1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
    2. Remove any curling by holding the edges diagonally and bending them gently.
    3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
    4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
    Paper Type
    Precaution
    Envelope*
    DL / #10
    Set paper with the flap closed.
    Unsuitable Envelopes:
    • Envelopes with an embossed or treated surface
    • Envelopes with a double flap or pressure seals
    Printer Driver Settings:
    1. Select Envelope in Media Type.
    2. Select the size for envelopes.
      * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
      * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
    3. Select Landscape in Orientation.
    Note:
    • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
    • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Don't forget to vote if this helps ... Cheers :)
    Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
    Printing from the photo tray
    I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
    Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
    Kodak 5300 wont print on glossy side of photo paper
    I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
    Hope this helps others
    Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Printing problem with MFC-665CW
    1. Take paper tray completely out of the machine.
    2. Remove the rear cover, clean the paper pick-up roller.
    3. Put rear cover back, put paper tray into machine.
    4. Copy a blank page for paper feeding test.
    Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
    Samsung CLP-510 Laser Printer Logo
    244 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
