Question about HP w2207 Monitor
When I turn on the computer and the monitor, the monitor does not recognize a signal from the computer. I have tried restarting the monitor and the computer, unplugging all cables including the power cables and reconnecting, I re-seated the graphics card, I tried using the VGA cable, but the monitor still seemed to be trying to recognize a DVI connection, even though the VGA cable was plugged in. Right after I turn on the monitor it says: VGA input, no input signal > DVI input, no input signal recommended setting, 1680x1050 After about 2 seconds it goes to sleep and that is it. No mouse clicks or keyboard strikes bring the monitor back. I know of no way to change any settings, reinstall drivers, etc. , because I cannot get the monitor to work, so I am effectively blind, whenever I want to test something out I have to manually shut down the computer and turn it on again. I encountered this problem in the past, and after much frustration and unplugging/re-connecting, the problem seemed to magically solve itself, but now it is back and nothing seems to work. The frustrating part is that it seems random, this started happening a few days ago when I tried turning on my computer.
  • 732 Answers
Kkjsr00, You must narrow down the faulty component!!! You must prove what is working and what is not working!! Beg, borrow, steal a "known-good" monitor to prove your pc is operating perfectly and will display the WIN-desktop screen on it. If your pc is A-ok then visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ kkjsr00, when strange and weird stuff starts to appear on the screen of "cold-cathode-fluorescent-lamp" back-lit lcd displays the first place I would look at would be the units internal "switch-mode-power-supply/ccfl inverter supply".. No, No, No, unit not going to sleep!!! SMPS/inverter going into SHUTDOWN mode having detected a fault condition with itself or other circuit and is trying to save itself from catastrophic, nonrecoverable failure. e.g. smoke, fire, burn down house, etc. Do some reading in my profile and those of other fixya tech's and you will find more than enough info to help with your problem. Good luck with repair of "flakey" solder joint or bad electrolytic filter capacitor PLAGUE problem. Yes, you sure have a lot of reading to do!! 12fixlouie or old file is louie12fix also try "buddymc" , "budmrtn" profiles for more info.
Posted on Apr 27, 2010
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
Monitor Not responding
you have a video board problem in your monitor, but before you send to fix try with a diferent computer or even a laptop using the same cables.
Jun 15, 2010 | Acer AL1916W 19" LCD Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
This monitor works just fine on my e machines computer but when i plug it into my hp computer it cant find a signal.
Hi, the problem seems to be that your computer, do not recognize “which monitor is being used.” Follow these steps to correct the problem. First (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, your monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). Restart your computer. I hope this solves your problem. Thanks paul7of9
Jan 14, 2010 | Acer 22" X223w LCD Monitor
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
I'm having problem with my 16 inch CHIMEI LCD monitor flat screen, first when i booted up my computer it was fine, then i just defrozted my computer(because my computer has a deep freeze program)and then...
in my opion deep freeze (pige head)is not good progrram .itt creat big problem. we should know well how can be use it. once a time u should reinstale it or formate ur computer,i hae facing many problem from my custmer. -----thanks
Jun 14, 2009 | Chi Mei Corporation 221A Monitor
It will say no signal
It would be helpful if you had some more detail to this. However if it's saying no signal, and you're sure that that either the VGA cord is securely connected at both ends, then you may want to check the back of your PC to see if there is another video card installed, and try using that one. I've seen this happen thousands of times.
Mar 06, 2009 | Computers & Internet
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
My monitor says no signal
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
Sep 17, 2008 | E-Machines eMachines Monitor E15T4
HP w2207 Monitor Logo
560 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
