Question about Pool & Spa
Where can i buy a no adjust start switch found inside the back motor area of my standard pool pump UST 1102 MOD# C48K2N143CIC 115/230 VOLT
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Use the contact feature on our web page, www.arrowmotor.net, with this info for a quote on the part. We keep most of them in stock. Please include the serial number so we know which version you have.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 26, 2010
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
My booster pump is much louder than last year. Can you oil it somehow
PLEASE DO NOT TRY TO OIL THIS, IT HAS A START SWITCH INSIDE THE MOTOR, IF IT GETS OIL ON IT IT WILL NOT ALLOW THE MOTOR TO START. AND CAN CAUSE THE MOTOR TO FAIL.
SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY, COST AROUND 125.00 TO REBUILD ONE OF THESE MOTORS. USE UTMOST CARE WHEN REMOVING WIRES FROM THE BACK OF THE MOTOR !
POOL PUMP MOTOR HAVE SEALED BEARINGS, THERE IS NO WAY TO OIL THEM, THEY NEED TO BE REPLACED. I DON'T RECOMMEND WORKING ON A BOOSTER PUMP, THERE A HARD ONE TO FIX .. SORRY .. JAY .. THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
Jun 04, 2011 | Polaris 280 In - Ground Pool Cleaner with...
Upon startup ...new season. Pumpstarted but when full circulation started pump shut down and seemed overloaded
well..you can start by blowing out the back of the motor with compressed air" where the wires go into tthe back of the motor cover" there is whats called a start switch there ! if this fails to fix it search for your local pool pump motor repair guy in your area and bring it to him for free testing.. CLICK HERE HOW TO REMOVE MY PUMP .. LAST prime the pump and make sure the filter needs to be clean
May 26, 2011 | Hayward 3/4hp Super Pump Inground Pool...
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Jul 14, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
How to remove motor AO Smith Model C48K2N143CIC
Take off the rear cover as to expose the capacitor. Remove capacitor. Place a 7/16 wrench on the shaft threw the opening where you removed the capacitor. Put a rag on the impeller and with a wrench turn it counterclockwise. It should come off easily. Make sure you replace the seals before reassembling
Jun 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Pump stopped working
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
If your pump has been leaking water it could be that rust has formed on the inside and is preventing the motor from operating properly. Which requires more aggressive dis-assembly to diagnose.
You can take it to a motor repair shop if the above listed doesn't work
Aug 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
