Question about Canon imageRUNNER 3570 Copier
Tried setting touch panel but buttons are so far left I can't select the button in service mode.
  • 1,219 Answers
You need to clear all in service mode. * 2 8 * function clear all ok.
With this kind of problem it can be tricky
Posted on Jun 02, 2010
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannot open the printer
AC driver PCB problem !
PCB needs to be replaced
Nov 10, 2013 | Xerox DocuColor 12 Printer
How do i get my xerox C7600 to stop beeping?
1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
3. Select the [System Settings] button twice. The System Settings screen will be displayed.
4. Select the [Common Settings] button. The Common Settings screen will be displayed.
5. Select the [Audio Tones] button.
6. Select the required option from the list, and then select the [Change Settings] button.
7. Select the [Save] button to save the settings.
8. Select the [Close] button several times, and then select the [Exit] button to exit.
Thanks & regards.
Jun 03, 2011 | Xerox Workcentre 5225 / Copier, With...
How do i change the number of rings for xerox workcenter 123 to pick up for receiving fax
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Fax Mode Settings]. The Fax Mode Settings screen will be displayed.
  7. Select [Fax Defaults]. The Fax Defaults screen will be displayed
You wll then see locations to set the amount of rings to answer, ECM mode etc.
Jul 23, 2010 | Xerox WorkCentre M128 Copier
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
THEFAX IS PICKING UP THE LINE AND NOT GIVING ME THE OPPORTUNITY TO PICK UP THE PHONE TO TALK
On the operation panel, press the following buttons to select DRPD.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select [DRPD], then press <OK>.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
On the operation panel, press the following buttons to select the correct ring pattern.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [RX SETTINGS], then press <OK>.
  4. Press the right or left arrow button to select [DRPD:FAX RNG PAT], then press <OK>.
  5. Select the proper ring pattern: NORMAL RING / DOUBLE RING / SHORT-SHORT-LONG / SHORT-LONG-SHORT / OTHER RING TYPE . Press <OK>.
  6. Press <Stop/Reset> to return to fax standby mode.
Feb 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Xerox 5665 beeping for all functions
Jul 03, 2008 | Xerox 5665 Copier
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Canon imageRUNNER 3570 Copier Logo
62 people viewed this question
old marine
old marine
