Question about Bernina Artista 170
My toolbar disappeared and I can't get it back. Please help.
Feed dog dial disappeared into machine. Cannot adjust feed dogs.
tech it to a sewing machine repair guy
who will fish the control back out and remount it
Dec 04, 2014 | Sewing Machines
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
I broke a needle and when I replaced it my nice stitching disappeared. Thread is very loose in the top of the machine. I misplaced the manual in a move, so I may not be inserting needle correctly.(?) I...
the flat side of the needle goes to the back of the machine
I also have the same sewing machine, if you will send me your email address thru a comment & I will copy pages of the operation manaul & send them to you
Oct 15, 2010 | Necchi 4595 Mechanical Sewing Machine
How do you use Singer Futura Editing Software?
Under submenu "Help" you can find different manuals and tutorials that describe all features. "Outline Edit" is intended for modifying the embroidery objects that were created by the native software (for example text blocks or AutoPunch Wizard result). With "Stitch Edit" you can modify specific stitches of any designs.
Main menu->Edit->Outline Edit and Stitch Edit
or two first buttons on the second line of the main toolbar or hotkeys "E" and "X".
Nov 07, 2009 | Singer CE-100 Futura Computerized Sewing...
EUROVOX MAXV CODES
all new software, updates manuals and everything else to do with eurovox is here http://allsportsforus.OurToolbar.com/
Download my toolbar for free and there is eurovox tab on it that will give u access to everthing.
Dec 12, 2008 | Euro-Pro Shark 60 - 384
Codes for eurvox
Dec 05, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
Editing downloaded designs
You have to have a design open to use the edit function.
Jan 01, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
47 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
