Question about HP DesignJet 1050c plus InkJet Printer
Black Printhead Failed 16 error message after i just replaced the printhead
  • Brian Cobb Apr 26, 2010
    I'm sorry but your options aren't feasible. This is a on a HP DesignJet 1050C Plotter (wide format printer). There is no option in software or on the plotter to select "clean printheads". I have actually replaced all 4 printheads and printhead cleaners, and have used the Carriage Interconnect Wiper to clean the electrical connections in the printhead carriage several times. Each time I have reset the printheads into the carriage I get one or more printhead errors. I just got the black printhead to be ok and now the cyan one says "Replace 20".
    Brigadier General:
  • 3,513 Answers
Please check this bellow link to get a solution to your problem...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01624398&cc=us&lc=en&dlc=en&product=3752462
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 26, 2010
  • 560 Answers
Hi. Please quote the name of the person you are referring in your comment. I posted solutions twice and it did not appear in my view. I don't know if you are referring to my solution. Thanks.
Posted on Apr 27, 2010
Printer screen had update message. After I pushed the OK button, it gave error code Oxba10AACC
Hi Wendy!
Sorry to tell you but OX___... messages means "failed printhead or ink system"
You should try to change the printhead because an error occured and the printhead it's no longer working
Hope you found it useful, for every futher question i'm here
Source: HP Troubleshooting
Dec 04, 2015 | HP Office Equipment & Supplies
Printer head
The error can be the result of firmware code, printer contacts or the printhead itself failing. There is a firmware update that addresses the "Printhead Error" on your printer. Please follow the steps below on how to successfully update your printer and provide information to the following questions:
1. Open the cover to remove the printhead and tanks (if installed). You may go to http://bit.ly/klw9sJ to have a visual on how to remove the printhead. Note: Carrier will come to the center automatically with this error message as the cover is opened.
- Remove the tanks and place on a table.
- Open printhead latch and remove the printhead.
- Close the printhead latch, close the printer cover, and confirm the error message goes away from op panel.
2. Proceed with the firmware update. Please visit the Lexmark website to download and install the update. Click here to download an important firmware update for your printer. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct. Please indicate if the update failed or successful.
3. If the firmware update software notifies that you have the latest firmware version, please inspect the printhead for the manufacturing stamp (http://bit.ly/vLvfCx ).
a. Is the stamp on the nozzle plate side?
b. Is the stamp on the contact side?
4. Open cover, open latch, and insert printhead only.
- Firmly push down on printhead then close latch and cover.
- If error message goes away, continue with normal installation steps for cartridges.
- If error message remains, open cover, remove cartridges, open latch, remove printhead, re-install printhead, close latch and install tanks cartridges firmly.
5. Try to print a document again to verify that the problem is fixed.
Please feel free to contact us at LxkListens@Lexmark.com
Nov 11, 2012 | Lexmark S815 Genesis AllInOne InkJet...
Message on printer screen says "The following printhead(s) has a problem: black/yellow (K/Y).
This probably could be defective Printhead ( black/yellow )
Follow the steps below and it should resolve the issue, if not, you need to replace the K/Y Printhead. You can purchase it from any nearest departmental store like bestbuy or costco or walmart etc or Call HP and order one.
Open the front access door. ( printer must be power on )
Remove the Latch of the Printheads
Remove the Printhead
Clean the Contacts with lint free cloth ( golden contacts or electrical contacts / not the nozzles )
Re-install the Printhead back in its position and close the front access door.
The printer usually goes thru initialization process. or Turn off the printer and turn on.
If you still get the error message, Replace the K/Y Printhead.
Regards,
Ron
// Rate this solution with 4 Thumbs to help us improve the support
Jul 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit?
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
May 24, 2011 | Canon Pixma MG5220 InkJet Printer
Office jet pro 8500 alignment failed error message -black ink intermittently fails.
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Kodak printer states printhead loose or missing, this error message came on when I replaced the introductory color cartridge, which occured 1 week after taking out of box.
To resolve this error:
  1. Open the printer access door.
    Disconnect the power cord
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead.
    • Unlatch the printhead:
      press the button in the upper-left corner of the carriage.
    • Lift the printhead out of the carriage.
    • Place the printhead in the carriage.
    • Press firmly against the target label on the printhead until it clicks into place.
  4. Install the color and black ink cartridges.
  5. Close the printer access door.
  6. Connect the power cord.
  7. Then follow the instructions on the LCD screen
Jan 23, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Error message re printhead.
To resolve the error condition:
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP DesignJet 1050c plus InkJet Printer Logo
2,036 people viewed this question
Seeker5211
Seeker5211
