Freeze ups. slow. - Computers & Internet
  • frankdanfelt May 11, 2010
    Need much more info such as make, model, number, what OS are you using, etc.
  • 38 Answers
Use cc cleaner superantispyware for more info www.freebannedinfo.com
Posted on Apr 26, 2010
Why does my Samsung galaxy centura freeze up overtime I try to log on to Facebook and runs slow all of the time?
Your Samsung runs slow all of the time because it has only 512 MB Ram and a single core cpu. You can install clean master from google play and run it or you can do a factory reset(! you wiil lost your data if you do this Menu" -> "System settings" -> "Backup & reset" -> "Factory data reset").
Nov 19, 2015 | Samsung Cell Phones
Won't freeze
Your Freezer calls for a harvest temperature of at least 16 degrees or lower. You are not reaching that temp. The condenser is probably dirty and needs to be cleaned. That is in the back of the unit. make sure the condenser fan is running also. it's a 12 volt motor. When they fail, they usually slow down. If it seems real slow, replace the motor. parts are available thru appliancepartspros.com
Jul 13, 2014 | Samsung RF265AA Bottom Freezer French Door...
Mylaptop is very slow. how can i fix it
Try running CCLEANER software... it's free and it works.
Jul 06, 2014 | Sony VAIO Computers & Internet
My games wont load but rather freeze and slow my pc
You need to tune-up your laptop through following these tips given below:-
- Disinfect your system using some reliable antivirus program.
- Run disk clean up (start > programs > accessories > system tools > disk cleanup.)
- Disable background services.
- Fix Windows registry errors with PC Fresher
- Defragment the registry if needed.
- Uninstall those programs,software's and games which are not in use.
Thanks
Dec 03, 2013 | Acer Aspire 5349-2418 - 15.6 - C B815 -...
Im not sure if its the problem or not. I have gone through 3 DROID X phones due to it locking up and being very slow. But after I received my third phone and it started in doing the same. I took it out of...
I had two Droid X phones that both locked up often. I never used a case, but I found that running custom Launchers (like LauncherPro or ADW) caused it to freeze more often. Also, if you feel that it's running slow, check to see if you have any apps that are constantly running in the background needlessly. Verizon's proprietary apps tend to do this a lot.
Mar 07, 2011 | Otterhouse Droid X Motorola Verizon...
Coils freeze up
Make sure blower is running at the proper speed, if it's running to slow do to bad bearing or capacitor, the coil will freeze up.
Check evaporator coil and filter to see if they are dirty if they are then the coil will freeze up
Check the charge if it's low on refrigerant the coil will freeze up.
If your not sure how to check these things, then you should have a HVAC company, check it out for you.
Jun 03, 2010 | Whirlpool ACC108PS Air Conditioner
Having freeze up and very slow loading of programs
I have EXACT same computer. Are you running WIN 7? It works great! Have you cleared out the temp folder? users/(your name)/appdata/local/temp. Empty as much as you can in this folder. Its only a temp folder. How about clearing the browser cache? Have you run disk defragmenter? Theres alot you can do. Clean out the cookies. INSTALL more MEMORY. I have 4GB RAM in mine. Open the box and Clean it with pressurized air. BLOW out that dust! It holds in the heat, which defeats the heat sinks sole purpose! Hope this helps.
Mar 02, 2010 | Dell OptiPlex GX280 PC Desktop
i suggest you 3 different ways to handle this.
1.if tou have a windows cd. just insert it and select windows repair and proceed to the instructions.
2.purchase any any good registry repair and computer optimisation software suchas IOLO SYSTEM MECHANIC ,REGISTRY MECHANIC, ADVANCED SYSTEM CARE etc.
3. to be cheap and effective, you may use trial version of IOLO SYSTEM MECHANIC.
these will optimise your pc automatically.
CHOOSE ANY METHOD YOU LIKE
I have a Whirlpool Refrigerator Model ED25RFXFW01 that is very slow to make ice. It also gets stuck very often during the dumping cycle. Is it clogged up or what?
is the ice too big? if they are, the ice size adjustment needs to be adjusted. if the water to freeze is big then it takes a lot of time to freeze it and ice produce is slow. also you can check the pressure of the water to the ref, it could be very high pressure. i hope i was able to help.
Jul 05, 2008 | Whirlpool Refrigerators
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
