Question about Jet Flo 04325143A Marine Heavy Duty Water Pressure Pump
How do i prime a gould jet pump - Jet Flo 04325143A Marine Heavy Duty Water Pressure Pump
  • 126 Answers
Turn pump on,pour water in the 3/4 plug on the top of pump.feathering the valve so its not open all the way.
Posted on May 17, 2010
Pump will not kick on all the time
Posted on May 05, 2013
2 Suggested Answers
  • 523 Answers
SOURCE: Removal of impeller and screw - is it clockwise or
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
Posted on Oct 03, 2009
What is the proper way to prime a goulds jet pump? Model# C48a93a06
Turn pump on, pour water in the 3/4 plug on the top of pump, feathering the valve so its not open all the way. I have also done it by putting a running hose into the fill valve at the top.
May 03, 2015 | Jet Plumbing
My 8 Yr old 1hp jet pump model JRD10 cycles on and off when i try to use hose at facuet?
I think the pressure switch is cycling your pump when there is a low demand. If your system has a pressure tank, it is waterlogged (has no air in it). If you shut down you system, drain the tank, and the restart you system, it should work. Most tanks are made to be pressurized to a certain pressure before starting up your system. Some tanks have a 'tire valve' on them for pressurizing with air.
Oct 29, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
HOW can I tell if a Goulds jet pump needs replacement?
pull the foot valve as it takes very little to allow the water to drain back out. Personally I would replace all pipes in the hole with heavy duty /high pressure plastic agricultural irrigation pipes
Aug 17, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Gould j5s, pump not going above 15 - 20 psi, does this sound like it could be a priming issue or not since it is pumping some water?
how much pressure do you want with a 15 to 20 psi, really what are you pumping house water, you need more pressure to supply a home like a 60 psi with an exterol tank
Nov 18, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
How to prime a gould j5 well pump no plug on top
you have to have electric power to use a jet pump more info needed as to what is going on
Nov 04, 2012 | Jet Flo 04325143A Marine Heavy Duty Water...
Jet Flo 04325143A Marine Heavy Duty Water Pressure Pump  Logo
5,139 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
