Question about Panasonic Heating & Cooling
Panasonic split ac , fan motor not working and remote section not proper working
rayname
  • 70 Answers
SOURCE: AC remote not working
www.gree-ac.com this is gree website you will need a model and serial number from unit I would contact them to see who your local suppliers are or online order remote m# and s# would also help if available
Posted on Jan 04, 2009
  • 400 Answers
SOURCE: i hve purchased panasonic split a.c. b4 1 month
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Posted on Mar 10, 2009
  • 1250 Answers
SOURCE: FAN MOTOR NOT WORKING
http://www.panasonic.com/consumer_electronics/bp_split_ac/pdf/CS(CU)-C18(24)DKU_sm.pdf
Go to this site. It has your unit manual. Check it for part numbers and possible solution. Hope this helps.
Posted on Sep 12, 2009
  • 20 Answers
SOURCE: panasonic split system fan motor overheas
put the lubricants or grease motor bearings
Posted on Oct 10, 2009
technic_7117
  • 38 Answers
SOURCE: Hi All, My Voltas Split AC
in the pcb board there is a switch called manual switch it will on ur unit just open the indoor flap.
Posted on Aug 20, 2010
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
Jun 05, 2016 | Heating & Cooling
I want to fix my split system ac.
You are referring to the air handler portion of AC. One of the fan blades is hitting something. Kill the power to all of ac and air handler and open up the air handler by removing the panel facing you exposing the fan. Manually turn the blade and look for the offender. Bend back into place, put back panel and tape up properly and turn all breakers back on.
Ir maybe just moving the fan motor itself slightly will do the trick. Whatever is easier and works will do.
Sep 08, 2015 | Heating & Cooling
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Panasonic split system fan motor overheas
Oct 10, 2009 | Heating & Cooling
Fan motor not working split ac
jump motor to proper voltage to test.
if it does not run it is bad and needs to be replaced.
Phil
Jun 11, 2009 | Dayton Permanent Split Capacitor Motor Fan
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Fan motor
I have the same problem with mine, I would love to know what to do to fix it. I have turned the machine off at the power box.
Mine is a Kelvinator split system
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
168 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
