Question about Microsoft Windows Vista Ultimate Edition
Thanks for the information (i ll try it with a little help from your side)
Dear Iqbal, thanks for the probable solution...i ll definitelytry that..however cou;d you let me know which driver to download from which website??? also I m not having a USB floppy drive handy with me....i tried the following websites but that didnt work....i think i m doing the slipstreaming proparly but the driver or controller required by my laptop are not available......IF YOU COULD PLEASE HELP ME TRACK THE CONTROLLERS I REQUIRE...I WOULD BE REALLY BEHOLDEN
heres the link for my compaq V3607tu specifications also there are some other links which might be useful for others but non working for me
1model number : V3607TU 2serial number : 2CE7401DR5 3pin number : GT983PA#AKL hdd: sata hdd with 120 gb space in bios sata native option unavailable
SATA drivers as from the HP website : sp32478.exe website url: http://tinyurl.com/2rv4mx
other support links http://tinyurl.com/ysryd2 http://tinyurl.com/2nzgz4 http://tinyurl.com/36wkg2
http://tinyurl.com/39a7yh mtorrent win vista mini xp your help in any regards is highly appreciated
  • 655 Answers
My openion is regarding USB floppy drive is not the solution, becoz windows XP setup could not recognize that. You can use USB Floppy only after complete boot-up of XP. So if you will put the SATA driver (i.e. RAID for F6) it will not work. Becoz as well as you will press F6 the setup will raise an error that no floppy drive is found as to access the USB floppy drive the USB driver must be loaded before of use.
Jigar here is the screen shot from my device manager:
Please take a same screen shot from your device manager and post it here. Then I can give you the actuall link for your SATA driver.
Thanks
Iqbal
Posted on Mar 24, 2008
SOURCE:
Cover open, but it isn't
We'll need a little more information to answer that. Please provide the make and model number of your printer. The brand and model name is probably displayed on the front of the printer but the full model number will be on a plate or sticker on the back or side of the printer.
Provide that and we may be able to help. Thanks.
Jun 03, 2015 | Office Equipment & Supplies
Can not ininstall psc2350 on to my lap top with windows vista as soft ware is for 2000,xp
you need to upgrade your driver.
Click here to get the drivers and supported software:
Download all and install it will work,
And please don't forget to rate this solution as Fixya.
If any problem just Aske me........
Thanks
Iqbal
Apr 06, 2008 | Office Equipment & Supplies
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link http://electronicshelponline.blogspot.com/ to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
Forgot my kindle fire password
Here is a quote from Amazon Kindle Fire Help "After four failed attempts at entering your password, you'll be directed to restore your device to factory default settings. This will delete all content on your Kindle Fire and you'll need to register it again before downloading items from your Amazon account. You can then create a new password for your Kindle Fire."
More information at
http://www.amazon.com/gp/help/customer/display.html/ref=hp_rel_topic?ie=UTF8&nodeId=200729330
Jan 05, 2012 | Computers & Internet
The refigerator is a little wobbly
Hi Wayne,
I believe I can describe the procedure.
1. Remove the front lower grille.
2. Look on the left and right front lower part behind that grille and you will see one of two things. Leveling legs or you will see bolt heads right over a wheel. These bolt heads are adjusting bolts. I ll go over the bolts because legs are fairly easy.
3. Choose the wheel in the front that is going to support your unit the best and turn the bolt just above it. It will be okay you can turn it with no problems you will see the wheel go up and down. Thats it.
4. I have posted a tip just below for you to read about leveling and doors. If you follow that you will be fine no laying the refrigerator down.
And please if you need further help all you have to do is ask.
A tip about doors.
May 29, 2010 | KitchenAid Superba KSRS27CN Side by Side...
I am trying to store numbers in my old 21 memory GE corded phone (Model No.2-9167A) Can you help me? Thank you.
Try this link:
http://www.home-electronics.net/USER-GUIDES/29169_DOM_EN_CD_IB.pdf
It's for a different model (2-9169), but I was able to store a number on my 2-9167A from these instructions. You'll have to lift off the plastic cover on the right side to be able to press the "Store" button - but you probably know that. Also, if you actually want to store more than 9 numbers (not counting the A, B & C buttons), then you'll use 01 thru 09 when storing or dialing. Good luck!
Jan 13, 2010 | GE 29322GE1 Corded Phone
2 gmail accounts one is not working, plz help
ive had a phone that had a gmail on it and now i can get in it ple help
Apr 23, 2009 | Google Gmail
I learn about repair mobile .
just take my id [email protected] and contect me i will try to give you all about software and hardware of cellphone
Dec 16, 2008 | Nokia 1100
Need a driver for my web cam
heres the website where you can download your driver
Nov 12, 2008 | Micro Innovations IC200C Plus Webcam
Microsoft Windows Vista Ultimate Edition Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
