I have a big screen Toshiba 57H83 that will not turn on. We have tried different outlets, so we know its not that. When you try to turn it on - it has a clicking sound like it is trying to come on but doesn'tt will continue to do that until you unplug it. Also the Red light in front does go off and on while it is clicking. Please help, it seems like maybe a simple switch that we can fix ourselves.
Thanks, JE
This 4 year old set looks dead.
It will not turn on and the red ON botton is dark.
There are no other symptoms.
It is plugged into the same power strip as the cable box which is ON.
This repair might no be a DIY, because there might be different failures on the TV. It could be the flyback transformer or the high voltage block or even a defective power supply, so I would not advise you to get to that high voltage area without knowing where and what to check.
There is some shorting in the main board
the screen is red and white with all cable programs
