Question about Cyberhome DVR 1600 DVD Recorder
The DVR keeps freezing on a frame. When it does,
The DVR keeps freezing on a frame. When it does, the remote will not do anything and then I have to unplug it and start over and then it will freeze on the same frame
    Scholar:
  • 103 Answers
Usually when a player keeps freezing on a single frame of a dvd, it means that the disc is scratched. When it "sticks", the dvd will usually stop moving (on the part of the disc with a scratch) and the remote will not work. First, look at the dvd and look to see if there is a visible smudge or scratch on the disc. Fingerprints are a common problem with dvds. I suggest you try to clean the dvd in case it is just dirty and if it still doesn't work, some companies make disc repair kits. You could probably find one at walmart or radio shack. These kits repair the scratches in the disc I hope this helps, and good luck! Sincerely, Der Strom
Posted on Apr 26, 2010
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
My pause button does not work on live tv. It will pause on DVR shows.
I have seen freeze frame but I do not have a clue as how to stop a live tv show, that is saying everything stops on the show until you release it. Some TVs can buffer the show but then it is no longer live. That is what the DVR is for.
Dec 05, 2014 | Televison & Video
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Jan 22, 2010 | DISH Network ViP622 DVR DTV Receiver /...
All Four Red Lights On, Cannot Use Remote
This is a new one-
I would try removing the batteries and letting it ferment overnight; it sounds like too many other electronic devices that 'hang up.' If you ahve the setup leased, they will send you a replacement and return mailing instructions.
BTW, don't let them bully you into paying anything for . . . anything. If you have been faithful paying them, they have a moral responsibility to keep their junk running. There's always DirecTV, doncha know?
May 15, 2009 | DISH Network IR Remote Control
BURNED DVD FRAME FREEZES
I have no problem with TDK DVD +R/W .
Jan 24, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome dvr 1600 Remote
codes for this dvr are
0714
0816
they don't work for my new remote but everywhere says they are right
Jan 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
253 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
