Question about Microsoft Windows Vista Home Basic Edition for PC
I can not find may boot disk - Microsoft Windows Vista Home Basic Edition for PC
  • Leonardo Hernandez
    Leonardo Hernandez May 11, 2010
    Could you say to me, if system cannt find it at start up? or please explain exactly what is the problem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
You can try this but I can not promise this will help you, but I have tried and succeeded
Posted on Apr 26, 2010
Need a boot disk, I do not work
It sounds like you need a boot disk for you operating system or you may have left a disk in your computer. In order too download a boot disk you will need to know what operating system you are using. You can try googling a boot system or go to a repair shop. the shop might sell you a disk or have you bring it in. I don't know if it is legal to download or buy a disk.
If you down load a boot file you will need to copy it on a disk on another computer. I am assuming your computer is not booting up. (Boot up means to turn on the computer which brings the system up). Sometimes one needs to go into CMOS and tell the computer which disk to boot from or other settings. If you don't know how to do this it is best to leave it to a pro as you can permenantly damage your system.
Jul 04, 2014 | Eclipse HDD Navigation AVN9904HD
Tip
Non-System disk or disk error
<p><b>Issue:</b><br /> <p>Non-System disk or disk error<br /><br /> <p><img src="reyjoshua07.jpg" /><br /> <p><b>Cause:</b><br /> <p>The current media is not bootable or there was a disk error in attempting to boot.<br /><br /> <p><b>Workaround:</b><br /> <p> <br /> <p>1. <b>Change Boot Media </b><br /> <p>If you are booting from either a DVD, CD, diskette or a USB drive, remove the media and boot from the hard disk. The media is either damaged or is not intended to be bootable.<br /> <p> <br /> <p>2. <b>Set the Correct BIOS Boot Choice </b><br /> <p>The BIOS may be configured to boot from the wrong device. If you suspect this, the device boot order can be changed in the BIOS setup. Be aware there little consistency in BIOS setup operations, even with the same manufacturer on different models. As such, these instructions are bit less precise than we'd prefer.<br /> <p> <br /> <p>Reboot and enter the BIOS setup. Often the BIOS displays the correct key to use briefly on screen or you may need to refer to the computer's user manual. Typically you hold down the Del, Esc, F1 or F2 key immediately after booting.<br /> <p> <br /> <p>Look for a section on Boot or Booting. Often this appears on top menu. Select the Boot option, and if necessary the Boot order choice. The Boot order choices should list the order of boot devices. Typically the CD is the first boot device with the hard-disk typically second. The diskette may also occur before the hard disk, which is acceptable, although this will slow your hard disk boot by a few seconds. Avoid USB and network boots before the hard disk unless you know for sure you are using them (which is exceptionally rare). <br /> <p><br />Save and exit the BIOS. It will force a reboot. See if this change corrects the issue.<br /> <p> <br /> <p>3. <b>Check Hard Disk and Cables </b><br /> <p>If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.<br /> <p>It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.<br /> <p> <br /> <p>Hope it helps,<br /><br />Thank you for using FixYa<br /> <p> <br /> <p>Best regards,<br />Reyjoshua07<br />
on Jan 24, 2011 | Computers & Internet
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
I WANT TO RESTORE TO FACTORY SETINGS
If by restore to factory settings you mean reinstall operation system ..you need either a recovery partition or disk ..to use ..or a boot-able disk with the operation system ..
if you have teh recovery partition just press teh key indicated on start for recovery and boot from the partition and proceed for recovery ..or insert the disk ..restart and press any key when asked for to confirm boot from cd ..and proceed with the recovery ..(same way for boot-able disk )
In case it does not boot from disk ..you need to press f12 on start to get to boot menu and select the cd and press enter to force boot from disk ..confirm by any key and go on ..
If you don't have any recovery ..try to borrow or buy or make a boot-able disk ..and install the operation from it ..either by changing boot order in bios or by pressing F12 on start with the disk inside ..select boot from disk and enter ...again press any key to confirm ..and follow instructions ..If you do not know how to do it ..and you are ready to do it anyway...follow one of my services ..and I will guide you by remote assistance to make a disk ..and after that find a way to guide you trough the installing (probably messenger )
Dec 23, 2011 | Computers & Internet
I HAVE A AOPEN COMPUTER IT IS A MILENIUM ONE IT NEEDS A BOOT DISK HOW COULD I GET ONE
Your computer tries to "boot" (restart itself) from several devices:
* 3.5-inch floppy-disk
* CD/DVD drive
* disk-drive
* USB memory-stick
* and others
When it cannot boot from one device, it tries the next.
So, either:
* you have changed the list of boot-devices to EXCLUDE the disk-drive;
* the list of boot-devices INCLUDES the disk-drive, but the attempt to "boot" from the disk-drive has failed.
Thus, the "insert boot disk" message says that all of the eligible devices were tried, and the "boot" from each of them has failed.
So, check that your disk-drive is INCLUDED in the list of boot-devices.
If it is, then your _REAL_ problem is that your disk-drive is either "logically" damaged, meaning that the "boot-records" on the disk have been overwritten, or "physically" damaged, meaning that *NO* information can be read from your disk-drive.
Take your computer to a qualified technician, to check the "health" of your disk-drive.
Sep 24, 2010 | Computers & Internet
When i start the laptop it shows media test failure,check cable exiting pxe rom os not found
Your computer is configured to try to "boot" from several devices:
* floppy-disk
* CD/DVD drive
* disk-drive
* network (via connecting to a "boot-server" on your local network)
So, "media test failure" means that no Ethernet cable is connected to the network-port on the computer. So, if you are trying to boot from a "boot-server" over the network, check that the Ethernet cable is connected, and check that the boot-server is processing boot-requests.
Thus, the PXE (Pre eXecution Environment) is exiting, because it cannot boot from the network -- no Operating System was accessible over the network.
So, enter BIOS SETUP, and disable the "network boot" option,
if no boot-server exists.
Also, put a boot-disk into the floppy-drive, or the CD/DVD drive,
or, most importantly, check that your disk-drive is working.
If your disk-drive is not getting power, or its "data" cable is not connected, or if the disk-drive has a problem, then Windows cannot be read from the disk, and so the computer tries an "alternate" boot-device.
Sep 03, 2010 | Computers & Internet
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Jun 12, 2010 | Symantec Norton Ghost 14.0: Windows
Boot Disks Required
Open my computer select A the floppy drive and do a right click and select boot disk
and enter
bye
Mar 24, 2009 | Computers & Internet
HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Nov 15, 2007 | HP Compaq nc6320 Notebook
Microsoft Windows Vista Home Basic Edition for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
