Question about Whirlpool Washing Machines
Start button is blinking but it will not turn on. We left it unplugged overnight but still doesn't work
  • 7 more comments
  • kgilbert38 Apr 27, 2010
    This is a Whirlpool Cabrio Top Load
    model-WTW6600SW1
    serial-CT4891901
    I am at work right now, but will have my husband try this tonight. Are there directions on how to put the washer in standby mode?
    I don't know if you received my previous email, but I will have my husband try this tonight.
    Thank you
    I will let you know if this works...Thank you!
    Okay...got it, I'll get back to you tomorrow.
  • kgilbert38 Apr 28, 2010
    My husband tried your suggestion and no codes came up on the console. The start button constantly blinks.
    It said to replace the console, which we just replaced a few months ago because we were getting an F1 error code. Any other suggestions?
  • kgilbert38 Apr 29, 2010
    Thank you, I see that there are a lot of problems with this Cabrio and Whirlpool doesn't seem to want to stand by their product. Thank you for your help and have a great day!
  • kgilbert38 Apr 30, 2010
    I'm sure we are going to have to replace the console again!! I did google this and can see everyone is having the same problems. I also emailed whirlpool, but I had emailed them before and never heard anything back. Thank you for your help and have a great weekend.
  • 10,515 Answers
If you could ONLY hear Beep and the Lights do not change, i am Sorry to say that this seems to be a Faulty Control Board. You need to Replace that to get this Resolved.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 28, 2010
  • taran_2005
    taran_2005 Apr 28, 2010
    Thanks for your response!!
    Oops!! I never checked the Comments. I would like to inform you F1 is a Common Error on Cabrio. It is Faulty CCU or Control Board. I think there is a Lawsuit against Cabrio for the same. You could Google the same and you would be surprised that How many people are facing the same Problems.
    Hope i helped you.
    Thanks
  • taran_2005
    taran_2005 Apr 29, 2010
    I understand your Concern. But, that is a Fact as of now. Any other information, you would like to ask or share.
    Hope i helped you.
    Thanks
    PS - Kindly Accept the Solution,if 100% Satisfied from my response!!
    President:
  • 1,554 Answers
Entering the diagnostic mode, if applicable to your washer, and performing the necessary tests can determine the cause of the problem. Please indicate the exact model number of the washer for a specific troubleshooting and repair advice. More information provided makes the troubleshooting fast and accurate.
Posted on Apr 27, 2010
  • 8 more comments
  • Jahn27
    Jahn27 Apr 27, 2010
    Activate the console and indicators diagnostic mode to check the
    functionality of the console buttons. Put the washer in standby mode
    then within 4 seconds press the following button sequence: SOIL LEVEL ---> WASH/RINSE TEMP ---> SOIL LEVEL ---> WASH/RINSE TEMP.
    A two-digit "dt" will display for 5 seconds if the entry to the console
    and indicators diagnostic mode is successful. Press the START button
    within 5 second of "dt" showing in the display. It should turn on all
    indicator lights while "88" is displayed; otherwise the console is
    faulty and needs replacement.
    Press again the START button if pressing it above worked as described.
    This will turn off the status indicators and the two-digit display.
    Press the START button for the third time to turn on the status
    Rotate the WASH CYCLE selector back and forth; it will toggle the cycle
    indicators on or off. Press the button one a time to verify the
    functionality. The indicators will toggle on or off and a beep will
    sound each time a button is pressed to indicate the button is working
    and the user interface board is good. Press the STOP or POWER button at
    any time to exit console and indicators test mode.
  • Jahn27
    Jahn27 Apr 27, 2010
    You can also check the major washer functions and view saved fault
    codes by entering the automatic diagnostic test mode. The recent fault
    code may indicate the cause of the problem. The washer must be in
    standby mode when entering the diagnostic service mode.
    Select a button, except START, STOP, or POWER, and using the same
    button, follow these steps: press/hold for 3 seconds ---> release
    for 3 seconds ---> press/hold for 3 seconds ---> release for 3
    seconds ---> press/hold for 3 seconds.
    All indicators on the console will light up for 5 seconds with "88"
    showing in the display if the test mode has been entered successfully.
    The program then checks for any saved fault codes. If there is no fault
    code saved, all indicators on the console will momentarily turn off,
    and then turn back on with "88" displayed and the automatic diagnostic
    test will begin after 5 seconds. You may open the lid to check and
    observe the operation of the washer.
    Press the same button used above in entering the automatic diagnostic
    test mode to manually advance through automatic test steps but step C1
    must be allowed to complete before advancing to the next step. Press
    START or POWER anytime to exit.
    Note: Select another button if the entry to the automatic diagnostic is
    unsuccessful and let us know if it cannot be activated after several
    attempts. Let us also know any fault code saved.
  • Jahn27
    Jahn27 Apr 27, 2010
    Simply unplug the washer for a couple of minutes and plug it back to put it to standby mode. Please accept and rate solution accordingly. Feel free to update us and ask for further questions if necessary.
  • Jahn27
    Jahn27 Apr 27, 2010
    The diagnostic test guide is not intended to fix the problem but rather to determine what is the possible cause of the problem for the necessary action to be undertaken.
  • Jahn27
    Jahn27 Apr 27, 2010
    Good luck and thanks for using Fixya.
  • Jahn27
    Jahn27 Apr 29, 2010
    Sorry for the delayed response due time zone constraints. Are both console and indicators diagnostic test and the service diagnostic test done successfully without a single fault code appearing?
  • Jahn27
    Jahn27 Apr 29, 2010
    Check the connection between the console the machine control and make sure it is good and snug fit. Perform a manual diagnostic test to check the lid lock mechanism and the console electronics.
    showing in the display if the test mode has been entered successfully. Press the same button once again during the 5 seconds display time of the "88". Failure to press the said button in the given time will start the automatic diagnostic test.
    A single beep sounds if the entry is successful and the two-digit display shows the console identification number for 3 seconds then displays "00" and the Add a Garment indicator LED flashes.
    It is sad to say but you have to replace the console electronics if the entry of the manual diagnostics is successful but the console ID number is not displayed.
    The lid must be closed to perform the manual lid test. Press and release the 2nd Rinse or the Extra Rinse ; the lid locks and the lid lock indicator turns on. Open the lid to verify if it actually locked. Press and release the same button again then the door unlocks and the lid lock indicator turns off. Open the lid to verify if it is actually unlocked.
  • Jahn27
    Jahn27 Apr 29, 2010
    If it turns out from the test that the lid lock is faulty, check the lid lock connection and make sure it is good and snug fit. With the lid lock wiring disconnected from the machine control and the terminals labeled 1 to 7 from top to bottom, check the resistance of the lid lock motor winding and the switches.
    The lid lock motor winding resistance , normally 30 ohms to 40 oms, is measured between pins 2 and 3. With the lid locked, pins 1 and 7, and pins 1 and 5 are close while pins 1and 4 is open. With the lid unlocked, pins 1 and 7, and pins 1 and 5 are open while pins 1and 4 is close.
    Replace the machine/motor control board if the manual lid test in the previous post has failed but correct readings are found above.
  • Jahn27
    Jahn27 Apr 29, 2010
    Perform an isolation troubleshooting if you are still in doubt regarding the source of the problem. Disconnect all components from the control board except the console to check if the blinking of the Start button stops. If it doesn't stop, it is pretty sure either the console electronics or the machine control board is bad. If it stops, unplug the washer then connect one of the disconnected components and plug the washer back. Do this with the other components until the component that makes the Start button blink is found.
  • Jahn27
    Jahn27 Apr 30, 2010
    You are welcome and thanks for using Fixya. Please consider accepting or rating the solution which gave you the most information and help you understand the extent of the problem.
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
Red light blinks 4 times, no video or audio
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Apr 27, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
How can i turn off the key lock without a remote control
Depends on the TV. Most flat panels require that you hold the POWER button for about 10 seconds to unlock the rest of the panel buttons on the TV.
Other TV's may require the same procedure, but just with a different button. If holding POWER doesn't work, try the other buttons on the TV.
All else failing, try unplugging it overnight.
May 09, 2011 | Televison & Video
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
May 06, 2011 | Bunn GR10 Coffee Maker
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
Mar 07, 2011 | Sharp Televison & Video
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
Rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Mar 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Washing Machines Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
