Question about Canon FAXB160 Plain Paper Bubblejet Fax
UNABLE TO PRINT RECEIVED FAX
MODEL CANON B140 (0LDER MODEL)
OTHER COMPANIES HAVE RECEIVED A CONFIRMATION THAT THEIR PAPERWORK HAS BEEN TRANSMITTED, HOWEVER; THE MACHINE IS NOT PRINTING. THE RED ALARM BUTTON IS ACTIVATED ...........................ANY SUGGESTIONS?
  • 217 Answers
Hello mate,
you have to replace Paper Feed Assembly (including paper sensor).
Unfortunately i'm not pretty sure you'll be able to find new spare parts....
Good Luck!
Posted on Apr 27, 2010
How to confirm message sent what is the code so i know the party is sent it to received it
There is a transmit report which can be auto printed for every fax message sent out. Go to menu, under the fax sub-menu, turn on the transmit report (under report).
Apr 10, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
I am trying to send a fax and the fax is reading sleep, does it mean the fax went through. I received a confirmation report.
You dont mention make or model...it is likely that your machine does not have to come out of the "sleep mode" to transmit...as long as the lamp came on when you sent the document..if it printed a conf. report saying it went thro you should be ok.
Oct 13, 2010 | Office Equipment & Supplies
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How to get a confirmation print out after a fax done
Open 1 Touch Speed Dial Panel. Press <Data Registration>. Press <Set>. Arrow down to (2.Report Settings). Press <Set>. 1.TX Report . Change from "Print Error Only" to "Output Yes". This will cause a confirmation report to be printed after every transmitted fax.
Oct 06, 2009 | Canon LaserClass 2050 Plain Paper Fax
Fax transmission verification
Like Sandman said, the fact you DON'T get an error repport is your confirmation.
Apr 17, 2009 | Canon FAX-L350 Plain Paper Laser
Canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
Canon FAXB160 Plain Paper Bubblejet Fax Logo
104 people viewed this question
old marine
old marine
