Question about HP Pavilion dv6000z Notebook
Disk importer stop working ,missing short cut
    Sergeant:
    Champion:
  • 305 Answers
Try doing a system restore back to the point it was working.
hope this helps.
Posted on Apr 29, 2010
Machine stopped working
This can be due to the fact that the program controller unit has failed within and has a short that caused the cut off in the circuit.
Remove the panel and check for short. check if any rectifier or capacitor within has shorted, normally since this panel board is epoxy filled the possibility of repair is less and must be replaced.
Also disconnect lines from the board to confirm if the motor or pump circuit is not shorted.
Jul 05, 2012 | Washing Machines
Internal HD accidentally deleted
Hi, Run System Profiler. It's in the utilities folder along with Disk Utility,
Have a look at the ATA bus. Does it list both disks or just your start-up disk and the DVD-drive?
If your second disk is not showing here then it may well have died. Even if it does show it may still be dead and the only way to make sure is to use a stronger tool than Disk Utility.
Unfortunately you may have to buy that and it's cost is not far short of the cost of a new drive.
I've known apparently dead disks come to life after a short spell in a freezer inside a sealed plastic bag. Unfortunatley they rarely stay alive for long - just long enough to copy important files!
Apr 29, 2012 | Apple Power Mac G4 Desktop
I have a sony laptop vgn-cs3agh/p.before few months due to virus my laptop did,t work properly after that i try to recover my laptop from my recovery disks.but my laptop should not recover perfectly.when i...
Hi Nayeem, It seems that the Recovery disks are failed.If you have never changed the preinstalled operating system that is provided in the computer, you can recover the computer by reinstalling the OS from the hidden partition which is in the computer.
You can access it using the F10 Wizard while the computer is booting. Please backup important data before you do it.
May 25, 2011 | Computers & Internet
I have a 2001 1800 engine Nissan Almera Tino. The rear brake pads need replacing how do i do this?
You said pads so is it disk brake in rear or drum ? disk have pads drums have shoes.
ok if its disk then its real easy to change them take tire off after raising car and theres two bolts at the back of the calibur one top and one bottom back those out then carefully slide the calbur off the disk ok then you will see two pads one inner and one outer they will look slightly different ok heres the short cut use the outer pad and place it agains the round center and use a large c clamp to press it flat then take it off ok know put new pads on and place it back on disk tighten the two bolts back in and put tire back on lower car know very important pop the hood and make sure the brake resivor lid is on good then get in car start it and pump brake back up dont miss that last step or you may not have brakes till you pump it up hope i have helped you.
Sep 11, 2009 | 2001 Nissan Altima
Acer Laptop Windows does not start up."system dll 32 file missing
take the drive to another computer to recover lost info then format it and reload a new install from the disk,then copy what you want back on to your computer,You will have a working system in about an hour
Hope this helps
Cheers MISTERDJ
Aug 16, 2009 | Acer Computers & Internet
Halfords brand 380122 grinder disc changing ?
If it is a late design, there should be a button, on the 'head' of the grinder, which stops the disk from turning.
Then you should have a spanner key, that fits in the nut that holds the disk on, turn in the 'Left hand down' direction to remove.
However, if it does not have the said mechanism,
you could always use 'Shock' treatment to remove the disk.
Take a hammer.
An old flat blade screw driver.
Now wedge the disk so it doesn't turn, and place the tip of the screw driver in one of the holes, of the nut that holds the disk in place.
Now strike, until it comes loose.
This method works every time, but there is a small amount of damage incurred.
ps. Don't hit your hand:)
It hurts.
Good luck with that.
Apr 26, 2009 | Saws
HP Pavilion dv6000z Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
