Question about Canon PIXMA MX700 All-In-One InkJet Printer
It won't print yellow - Canon PIXMA MX700 All-In-One InkJet Printer
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Yellow ink won't print
Verify the ink level and perform in the mantenace mode head cleaning.
Feb 21, 2013 | Canon PIXMA MX860 All-In-One InkJet...
HP Officejet Pro K8600 won't print in color, just in black
Ink levels are an estimate. They are approximated according to how much color might have been used. You may be out of all the color inks, they may be dried out or clogged. There should be a head cleaning operation for the printer, but it uses ink too.
Feb 07, 2018 | HP OfficeJet Pro K8600 Printer
Even with new inks, magenta and yellow won't print
The ink you replaced costs as much as a new printer that comes with ink. Get a new one.
Aug 27, 2012 | Epson Stylus 2200 InkJet Photo Printer
Will not print . yellow empty
It won't print until you replace the empty yellow with a non-empty yellow.
For future reference, you will want to include more information such as make and model of device and if you are dealing with ink or toner.
Aug 03, 2011 | Office Equipment & Supplies
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Yellow won't print
First try to replace the yellow toner cartridge. After that, try re-seating the cartridge (take out the cartridge and place it back in carefully making sure it is seated correctly). If this does not resolve the issue, clean the print heads and connections on the cartridge. This can be done by removing the cartridge and swabbing the connections with a Q-tip dipped in rubbing alcohol. Also, while the cartridge is removed, swab the connections to the cartridge that are inside the printer where the cartridge is seated.
May 09, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
CANON PIXMA IP2000 STOPPED PRINTING YELLOW A FEW MONTHS AGO. WE'VE CHANGED INK CARTRIDGES MANY TIMES, BUT CAN'T GET YELLOW TO PRINT. HOW DO WE REMOVE THE PRINTHEAD SO WE CAN TRY TO FLUSH IT OUT WITH HOT...
OK, since nobody answered my plea for help, I merely opened the Canon monster and yanked out the printhead after lifting up the level. (WHAT was so hard about that, that nobody could explain it here?!)
Cleaned printhead using warm water & ice-cube tray & paper towes. Just let it soak all the excess ink out for a while, then allowed it to dry.
Changed cartridges, put new color cartridge in...
THE DAMNED THING STILL WON'T PRINT YELLOW (altho it will print a faint hint of yellow). WHY IS IT DOING THIS? Why is Canon making this a common problem in the first place, rather than producing a product that is reliable and easy to maintain?
Nov 19, 2010 | Canon PIXMA iP2000 InkJet Printer
Printers lines are squiggly
calibate the print cartridges
if not solved then clkean encoder strip ( a thin Clear Strip )
check Carriage movement Belt , If REquire Replace
Feb 04, 2009 | HP DesignJet 750c plus InkJet Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
