Question about Hotpoint RGB745 Gas Kitchen Range
PILOT LIGHT IN BAKE OVEN WILL NOT LIGHT - Hotpoint RGB745 Gas Kitchen Range
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 27, 2010
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
The oven/stove is from the 70's and the pilot light is on but the oven will not heat up. help
Thank you for bringing me back to the early days of my appliance repair career,now a days every thing uses a electronic ignitor and its been a while since i have seen a free standing pilot :)
As far as your oven,when you turn on the oven does the small pilot light increase in size,if not the oven thermostat is the most likely problem and for the most part the thermostats are no longer avaliable. If the pilot size increases the pilot burner could be not properly heating a small bulb in the pilot burner,the pilot burner could be cleaned by a senior tech that knows how to do it correctly OR the small bulb is heating and what that the bulb attaches to (the gas safety vavle) is not opening to allow gas flow to the main bake burner
Depending on your exact model (what parts were used when it was built) the pilot burner and gas safety valve are still avaliable
Gene
Jul 30, 2011 | Tappan Kitchen Range
My gas oven will not start up to bake
The most common problem,
1. if your oven uses a pilot light..it blew out
2. if it does use a pilot lite, you have electronic pilot..if so the glow plug is burned out...
If your top plates go click click click to lite, you have electronic pilots
Dec 19, 2010 | Kitchen Ranges
Burners work,Broiler works but oven does not preheat
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Jan 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Oct 28, 2008 | Premier P36S318BP Gas Kitchen Range
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
Jun 19, 2008 | Magic Chef Kitchen Ranges
GE Spectra XL44
Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
Oct 23, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Hotpoint RGB745 Gas Kitchen Range Logo
159 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
