Question about YouTube Videos
Youtube is blocked in our blocked ...do u hv some procedure to open it?
  • 812 Answers
Hey welcome to fixya. I hope u 'll be fine.
u can use different proxies to open the youtube , just give the address of youtube there, it 'll open for you itself, there are many different proxies given below.
  1. http://www.utunnel.com
  2. http://www.vtunnel.com
  3. http://www.cecid.com
  4. http://www.bywhat.com
  5. http://www.pearlproxy.com
  6. http://www.proxylord.com
  7. http://www.snoopblocker.com
  8. http://www.3proxy.com
  9. http://www.proxyfy.org
  10. http://www.proxify.info
  11. http://www.anonproxy.info
  12. http://www.proxyweb.net
  13. http://www.pole.ws
  14. http://www.nopath.com
  15. http://www.browseany.com
I hope lots of proxies mention above 'll work.
I hope your problem will be solved.
If u think that it was helpful Then Please do rate me
Note: Use them with caution, you know what u r doing, Fixya 'll not be responsible for any rules and regulations you violate from using these proxies
THANKS
Posted on Apr 26, 2010
How to unlock youtube in school
Use your own wireless tablet, iPad, or cell phone with your own internet service provider.
School administration may have a security policy to block it, and you would be subjected to their disciplinary procedure, which is not recommended.
Mar 27, 2018 | YouTube Computers & Internet
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
Whirlpool microwave keeps opening high voltage diode
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...). Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or sometimes in interlock switch assembly or PC Board.
First, you must be sure which diode is blowed, reactifier or protect diode.
To check magnetron following this procedure:
Discconect the mains supply.
Check that the capacitor is discharged (by resistor 100 ohm / 10W or more).
Discconect the magnetron.
Measure the resistence between the disconnected terminals (should be app. 0.5 ohm).
Measure the resistance between the supply terminals (both) and earth. The resistance should be infinite.
Dado
Mar 12, 2015 | Whirlpool MT4155SPS
Is magnetron replacement procedure difficult ?
It should not be too difficult, but the fault could also be a failure of the HV transformer or the big capacitor in that circuit.
http://www.repairfaq.org/sam/micfaq.htm
As you may be aware, the main precaution is to make sure the HV capacitor is fully discharged before you work on that circuit.
https://www.youtube.com/watch?v=OFFzS1a6k5g
Some have a self discharge resistor, but that also can fail. Here is a typical circuit
http://www.microtechfactoryservice.com/images/doubleranim_a.gif
and the diagram for your unit may be pasted to the inside of the casing. If you are sure it is the magnetron, you only have to discern the mechanical fixings of it after that.
Mar 22, 2014 | Bosch Microwave Ovens
I can't watch youtube vids!!!????
try this to check your network firewall
1. open command promp
2. ping youtube.com
3. if its reply request timed out mean your administrator block all access to youtube if reply well mean your admin only block streaming video.
Mar 04, 2011 | YouTube Videos
I hv a nokia 7210 cellphone. bt the 1 gb memory card becomes password protected. how i can open it?
I suppose you didnt insert any password to your memory card.If you didnot put password then you can unlock the memory card by seeing the below youtube video
http://www.youtube.com/watch#!v=Be_aHSlDFCU&feature=related
Thank You
Aug 11, 2010 | Nokia 7210
Youtube in pakistan is blocked tell me a different way?
You can use http://www.accessyoutubefromwork.com/access-youtube-in-pakistan/ to access youtube in Pakistan. Enjoy your weekend with Youtube Videos.
May 26, 2010 | YouTube Videos
HOW OPEN YOUTUBE WHEN IT IS BLOCK
how open youtube if it is blocked
Apr 16, 2010 | YouTube Videos
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
KP-43HT20 convergence box
Remove PCB w/largest heat sinks.Locate STK IC's. Replace both IC's for reliable repair. Check pico fuses near IC's-if open,replace with same value. Note:No hv to be discharged.However,care is needed removing HV lead from HV block- Slide rubber cap back,push lead in slightly,turn cc 1/4,then release straight out from block.Easy does it!
Oct 05, 2007 | Sony KP-46WT500 46" Rear Projection...
YouTube Videos Logo
207 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
