Question about GE A730 Digital Camera
Lens error when I power on the camera, the lens comes out, then quickly closes and it says 'lens error' and shuts down
  • 8 more comments
  • 1513 Mar 25, 2008
    we have the same problem - lens error and then shuts off
  • Anonymous Mar 27, 2008
    same issue here. help!
  • bleigh12 Apr 07, 2008
    my camara will come on in play back but in camara mode the lens comes out then the screen says lens error and shuts off the lens does not close
  • ndougb Apr 07, 2008
    My camera is doing exactly the same thing.
  • lchaz99 Apr 25, 2008
    I have the problem of the lens not going in. I have only used this camera on one occasion and around the house a bit. The solution did not work for me. Any other suggestions?
  • robbinbuck10 May 14, 2008
    My camera has been acting fuuny - lens error - I fixed it the other day by just cleaning it but now it will not come out at all. Every time I turn it on it shuts down and gives mwe an error message about the lens. Since to be a problem.... need help! Tired the soloution that was offered at the end of the page and that did not work!
  • Anonymous Jun 08, 2008
    lens error too
  • x0kaaylaa0x Jul 12, 2008
    its the same. i turn it on and it closes and on the screen says "lens error"
  • laneyxannx91 Aug 03, 2008
    same problem. i turn my camera on and the lens comes out, then says lens error and shuts down.
  • jenniferd131 Sep 08, 2008
    i tried to blow out dirt with hair dryer did not work not sure how to fix but i don't like this ****, new camera and now it don't work urghhhhhh what else can be done to fix lens error help please
My daughter had this same problem with her camera. We tried everything to get it fixed including the compressed air thing and it didn't work. Then I read somewhere to lay the camera face up on a flat surface pointed toward the ceiling. Hold the shutter button down at the same time hold the power on button down and it should try to focus while the lens barrel is extending. We tried that and it worked. Her camera is as good as new!! Hopefully this will help you guys as well.
Posted on Sep 02, 2008
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Posted on May 26, 2008
Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Posted on Apr 11, 2008
My lens is stuck open, every time i try to turn it on a lens error message pops up then quickly shuts down, wat can i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 29, 2010 | Nikon COOLPIX S200 Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
When Turning on the Canon Power Shot A530 the
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Lens wont close properly
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Jun 01, 2009 | Sanyo Cameras
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Cannot reset camera
I was having the exact same problem. The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Dec 12, 2007 | HP Photosmart R725 Digital Camera
Lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot SD850 IS Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
GE A730 Digital Camera Logo
76 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
