Question about Dolphin Maytronics Advantage
Cut cord I purchased a used dolphin advantage cleaner at auction, the cord is cut about 8 in. from the unit, the rest of the cord is missing. I was just going to order a new cord, but after reading some post i read that the motors last only a few years, and this unit is mark mfg. 06. Is there anyway to test the motor before buying a new cord? Thank You Pat
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Yes but it is going to be tricky. You will need to open up the power supply and pull the black and white wire from the cable socket. Note what position they were connected to for reassembly later. Now strip the cable back enough to get to the wires inside and connect them white to white and black to black. Turn the dolphin upside down (tracks towards the ceiling) and turn it on. It should go thru a series of motions lasting about 30 seconds and then stop. If it does it has just passed a self test and will likely work in your pool. For parts or to have this test and others performed in a service center contact us thru www.arrowpools.net using the dolphin button along the bottom of the page.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 26, 2010
  • FryDitty Jun 07, 2011
    My Maytronics end that goes into the transformer pulled completly apart. No idea of which 4 positions the black and white wires go into. I tried 1 and 3, 2 and 4 but unti does not moved. Did not try 1and 2 or 3 and 4.
  • John Prohaska
    John Prohaska Jun 07, 2011
    White to port 2 and black to port 3.
My dolphin diagnostic pool cleaner purchased about 3 years ago stopped working last year (just after the warranty expired). This year I have tracked the problem to a continuity issue in the floating...
It will not run upright AND out of the water without sensing it is not in the water and upright...it shuts down, hence the self-test which is with the unit inverted...
It is most likely an issue in the motor pack with the board. Parts are not sold for the motor pack; only new motor packs. If you are still looking to do something with the unit please contact us thru www.arrowpools.net for possible solutions, parts pricing or directions on sending it in for inspection/service.
John
Jun 29, 2011 | Dolphin Maytronics Advantage
On starting, tracks roll one way for a few seconds, then reverse for a few seconds then stops with no further movement. Pump impeller does not move during this time. Impeller can be rotated by hand. No...
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site.
John
Dec 14, 2010 | Dolphin Maytronics Diagnostic Robot...
I have a Dolphin Diagnostic Advantage Pool Cleaner. It's worked fine for the past 2 years when I purchased it. Put it in the pool today and it's not working like it usually does. It runs for roughly 54...
<span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">Thank you for posting your question here on <a href="http://www.fixya.com/">Fixya.com</a>.</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: <a href="http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up">http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up</a> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">If that is not enough, try our sites FAQ section on Dolphins at <a href="http://www.arrowpools.net/"><span style="COLOR: purple">www.arrowpools.net</span></a>. Select the FAQ button then from the drop-down select Dolphin.</span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <st1:personname w:st="on"><span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">John</span></st1:personname><span style="mso-bidi-font-size: 10.0pt"></span>
Aug 27, 2010 | Dolphin Maytronics Advantage
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Jul 30, 2010 | Dolphin Maytronics Advantage
I place my dolphin unit in the water, then turn to
John
Jul 25, 2010 | Dolphin Maytronics Advantage
I have a dolphin pool cleaner and the pump runs intermediately
Your motor unit is not working and needs to probably be replaced. Individual motors inside the pack can not be replaced; only the whole assembly. For further information or for pricing estimates, please select the Dolphin button on the bottom of our website at www.arrowpools.net.
May 15, 2010 | Dolphin Maytronics Advantage
The renters of my house destroyed the power cord of my Dolphin diagnostic. Where can I buy parts, or just have service on the unit?
Many motor rebuild shops specialize in pool and evapritive cooler motors. This would fall into the first catagory. Usually youi can find these in the Yellow Pages. This can also be done with a good leingth of "S" cord and a plug but the connection at the unit needs to be water tight and should be done by a qulified shop. Good luck.
Feb 28, 2010 | Dolphin Maytronics Advantage
Download a manual for the Dolphin Diagnostic Advantage?
Found mauals on the Maytronics site.........Thanks for being there, though!!
Jul 09, 2009 | Dolphin Maytronics Advantage
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Dolphin Maytronics  Advantage Logo
362 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
