How do I get HDMI off of my RCA surround system/DVD player? I have it all hooked up right but I don't have a picture and the DVD player is set up for HD but I don't have HD TV.
  • Amanda83 Mar 24, 2008
    I got it figured out thanks! My TV is not HD and the guy I bought the system from had it set for HDMI so I got sound but no picture but I found out to shut off HDMI you hold down the subwoofer button. I didn't get the manual with my system so I had to look it up on the internet. Hope this helps someone who may have the same problem as I did.
    Sergeant:
  • 247 Answers
You have to select the correct input on your TV and surround system. for example select HDMI 1 or two on the TV and DVD or what ever input you have it connected to on the surround system.
Read the instruction manuals for more information.
Posted on Mar 24, 2008
I have a toshiba tv and a sony dvd player and i want to know how to install the jacks and if i need the hdmi cord
It really all depends on what else you may have hooked up and, what inputs you have on your TV. If you have an open HDMI in on your TV, I would use that because you will get your sound and vidoe with one cable(HDMI). If you don not have an open HDMI port on your TV, component cables are the your next best option video wise. The component cables do not carry sound so, you would have to get your sound by using,(best) digital optical or RCA. After looking at your player, your best picture would be using component and, it says it has SPIDF out but doesn't exactly specify what kind but, if you don't have the component cables, use youe RCA jacks(yellow), video out, and red and white(left and right audio) out from player to suitable input on TV. If I looked at the right player, there is no HDMI out on it.
Jul 02, 2011 | Sony DVP-SR200P DVD Player
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
