Question about Brother MFC 7840W Printer
Toner life end message but i have a brand new toner
  • adi May 11, 2010
    are you 100% sure the toner is new? I have had a few customers bring in printers where i look at the toner cartridge and its not. Check on the left side, there should be a white or black tab that moves 180* on its on. when its new, its on the left side, if its old, its on the far right. check that.
  • 4,041 Answers
Hi there
You need to reset the count in the Menu
All the best Pineworks
Posted on Apr 26, 2010
4 Suggested Answers
  • 5 Answers
SOURCE: Toner cartridge is full - "toner life end"
when the printer is in "ready" state, press the GO and SET at exact the same time.
Now, using the (-) < button you can choose any "service" option to fine tune te printer
TONERLIFEEND is the first in the list, press the "set" button en chose "Nothing" and press "Set" again
Posted on Jul 13, 2009
  • 4 Answers
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Posted on Oct 21, 2009
komguy
  • 2306 Answers
SOURCE: Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Posted on Jan 04, 2010
Toner life end message despite new toner
. To reset the "Toner Life End" message on the Brother MFC-8460N Open door press Clear/Back key
Apr 22, 2014 | Brother MFC-8460N All-In-One Printer
Hi, just replaced my toner on the MFC-7220 and a message Toner Life End is displayed and will not print. I have tried 2 brand new toner cartridges. Thanks, Linda
Hi there !
Try this solution if it works, the memory of your printer still programs that your toner is end.
Try to make hard reset of your printer by turning off your printer for 5-10 mins, unplug the power cord as well and remove the cartridge toner. Then return back the cartridge, plug the power cord and then restart your printer. Then try to print again.
If displaying still this message, just press stop button to remove the message.
Also, if there is wiper for cleaning the toner cartridge everytime your put new toner, please do it.
This is what we do in your bother MFC printer when this message appears. Just restart the printer and keep pressing stop button when the printer starts.
I hope it helps you. Regards.
Jan 31, 2011 | Brother MFC-7220 All-In-One Laser Printer
After changing the cartidge to a brand new one the printer still gives a message that the cartiridge is at the end of it's life. How do I fix the printer so it can properly detect the status of the...
ok here is the procedure for that.
1) open the front cover of the printer ..that is the cover that allows you to pull out the drum/toner, but leave them inside the machine
2)push the options button:located on the left side of the control pad)
3) type *00 on the keypad
this will reset the printer and the "toner end of life" message should go away, leaving your printer thinking it is brand new again !
Dec 17, 2010 | Brother MFC-7820N Laser Printer
Jan 04, 2010 | Brother DCP-7040 Laser Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner life end error message after replacing toner on my mfc9440cn
I took the printer back to staples and returned it. exchanged it for a new printer.
when I brought it home, the new cartridges worked just fine. It was not the cartridges, it was the printer's problem. Thenk goodness i bought and extended warranty on the printer.
The cartridges were brand new and name brand so it didn't make sense that it could be that all 4 brand new cartridges were having a problem!
Jun 07, 2008 | Brother Office Equipment & Supplies
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Toner life
where and how to find the reset actuator?
Nov 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7840W Printer Logo
1,556 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
