Question about Dell 1815dn All-In-One Laser Printer
I keep getting black spot on my copies< and nothing is on the scanner
  • 4,041 Answers
Hi there
It is on the mirror inside the printer, it need to be cleaned
Posted on Apr 26, 2010
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
I'm getting black lines when I print or copy on my Ricoh Aficio 3228C. It looks like they're caused by the rollers. Does anyone know how I can clean or resolve this issue?
looke my friend black lines have many reasons on of various reasons rollers in fusing unit may be scratched if it like that use marker black pen and put pen in spots of scratch area sconde reason pcr primary charge roller and scanner filter
Feb 09, 2011 | Ricoh Office Equipment & Supplies
When i use the sheet feed on my hp laser jet 2840 to photocopy the printed page has a black line down it what can i do to get rid of this?
Clean the adf scanner glass. This is the thinner strip of glass that is just to the left of the large original glass. Just lift up the top feeder and look to the left side of the glass. Clean this strip of glass with a soft cloth and some glass cleaner. Sometimes whatever is stuck to the glass is hard to get off so keep at it till it goes away. Another tip is if the line is in the middle of the copy then the "spot" to clean is going to be in the center of this strip from front to back. If the line is to the left side of your copy then the spot is going to be towards the front side.
Good Luck and Than You for using Fixya
WheatlandServices
Nov 14, 2010 | HP LaserJet 2840 All-In-One Printer
I have a Ricoh Priport VT2250 duplicator. I keep getting an error
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
May 26, 2010 | Ricoh Priport VT6000 Copier
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
I keep getting a scanner failure when I try to fax something from my all in one Officejet k60.
i can understand the situation here is the soluition for you :
1.TRY TO MAKE A COPY
2.if the copy does not happen open the scanner glass and check whether the scanner lamp that is tdo you see any light in the glass glowing or moving
3.if nothing gloes or move then i am sorry to say that you will only be able to print from the printer and nothing else
4.if the printer is in warranty call hp they replace it for you .............................. thank you and hope you do see the scanner lamp
Oct 20, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Feb 25, 2009 | Lexmark X4875 All-In-One InkJet Printer
Black line along page in copy and scan modes,not in print mode
Your scanner lamp is dirty. Take apart the scanner glass and clean the lamp. (Look for contaminated spots on the scanner lamp).
May 23, 2008 | HP Photosmart 2575 All-In-One InkJet...
Dell 1815dn All-In-One Laser Printer Logo
100 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
