Question about Belkin (F5D5231-4) Router
Cannot connect It says 'Acquring network address' and won't connect
  • Leonardo Garcia
    Leonardo Garcia May 11, 2010
    Are you saying the router is acquiring network address or your "computer"when you connect to the router? I ask you this because it could be the DCHP server on the router (the ones who gives the "network address" or the modem which gives the network address to the actual router. Can you be more specific?
    President:
  • 1,768 Answers
1. connect with a Ethernet cord if you speaking wireless. this will verify that the router is getting signal from the ISP.
2. clone the MAC address restart the router
3.if still no connect reset the router.
Try doing and release/ renew
Posted on Apr 27, 2010
Sapido firmware problem
Connect to it with a ethernet cable and try again. Since you reset the device it won't have your wireless network configured. Since you are no longer connecting to it via wireless, you are getting the 169... address. Once you connect to it with the ethernet cable you should get an address from the device. Then go to http://192.168.1.1 and user the user name admin and password admin. You should be able to reconfigure your wireless network from there. http://www.sapido.com.tw/EN/faqrb1632.htm
Oct 16, 2012 | Sapido RB-1632 3G/4G Mobile Hotspot and...
Printer is installed for wireless with network. constantly goes offline and requires re-installation.
The issue is with your router. Without knowing anything else about your network equipment I can tell you the following.
The lease on the network address for the printer keeps expiring or another machine on your home network keeps taking the address while the printer is still leasing it.
The solution is to access your router's configuration page and basically reserve a network address for the printer.
That way when the lease for the printer's address is up, the router will just re-assign that address to it. Your computers also won't need to re-install the printer either because it will always have that network address.
As for another machine taking the address, you'll want to make sure that all the computers that connect to your network are set to dynamic (DHCP) network addressing. That should keep your printer online for a good while.
Aug 15, 2011 | HP Officejet H470 InkJet Printer
I have a Linksys WRT320N wireless router connecting my PC and 3 netbooks. 3 netbooks stuck "acquiring network address" after establishing wi-fi protected set up for my BlackBerry Torch. How do I...
If your 3 notebooks were already configured with router and then you used WPS to connect your blackberry, then it must have changed the wireless settings of the router, due to which the router and the 3 notebooks are not able to communicate now and due to that, the notebooks are showing acquring network address as they are not able to get an IP address of the router.
Solution: You need to open the interface of the router and check the new wireless settings and then put those wireless settings into your 3 notebooks. You may use this link for detailed instructions, or you may also chat with the technician available for chat on that website. Check or Change WirelessPassword
Jul 10, 2011 | Linksys Computers & Internet
Cant connect to the netgear N600 router, keeps me at the acquring network address screen. what do i do!?!?!? I do not know what setting to change in the router to let this computer go through. This...
First thing you can do is a ipconfig /release /renew
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Dec 15, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Acquiring network address
all that you need to do is to delete the preferred networks list from the computer,
and try to scan and connect to the network again....make sure that you are typing the correct security key.
still if the problem exixts, then add the network manually...the problem will get off for sure....
also if there is any facility like wi-fi protected security is enabled in the wireless router, go ahead and disable it...
Apr 03, 2010 | Linksys WRT54G2 Wireless Router
I have an Advent 7088, after windows update loaded I can not get on the internet just keeps saying acquring network adress then not connected in a loop all the time.
type cmd at run and then check whether you have configured your IP address correctly by typing ipconfig at cmd. If it is not properly set then you need to set that one properly
Sep 02, 2009 | Computers & Internet
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
Acquring network conections
do you know who set up your router im guessing its not you as you dont have your wep key if you do have it its easy if you dont you need to connect to your router with a cable to get the wep key once done you mat need to set up your ip address on your laptop it should be 192.168.0.2 with a sub mask of 255.255.255.0 and a default gateway of 192.168.0.1 and a primary dns server of 192.168.0.1
any more help just ask
Oct 29, 2007 | NetGear DG834G Router
Belkin (F5D5231-4) Router Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
