Question about Kenmore 62602 Electric Dryer
How do i replace the belt on my model 70 series kenmore dryer
Stock # of dryer 66702690
belt # 341241
thank's
m j. k.
    Novelist:
  • 145 Answers
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Posted on Apr 27, 2010
I have a Kenmore 70 Series Model/Stock NO 97576200 75762. The dryer will not start but when plugged in the inside light turns on. When i close the dryer door, the light stays on and nothing happens. My...
your correcto a mundo-thats what it is,the switch is a single-pole double throw and the contacts are welded together and wont switch when you shut the dryer door to run the unit
Oct 16, 2010 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Kenmore Soft Dry,
Try popping the lid and inspect the belt. I did one for friend. On his when the belt broke, the dryer quit. It has a built in safety switch. Sorry don't know the series. His was 15 years old plus...
Sep 13, 2009 | Kenmore 63942 Dryer
Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Jun 22, 2009 | Kenmore Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Kenmore 62602 Electric Dryer Logo
361 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
