Printer does not want to print in colour just after I replaced the cartridge. What could be the problem?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
  • 666 Answers
You need to go into the menu on the printer and reset the error count to tell the printer it has a new cartridge for use
hope this helps
please leave feedback
thanks
Robb
Why am I missing colors on prints
Could be the print job you send to the printer is set up to print in black and white.
Or the cartridges are full and the nozzles from the printhead are blocked.
Run a cleaning cycle on the printer. If some colour appears continue till all colours are back for all nozzles.
If you did not use he printer for a long time, remove the cartridges one by one and put a drop of cleaning fluid in the pipes in the cartridge holder (where the ink goes in) tun replace the cartridge and print one or two full sized colour photos, till all colours are back.
Jul 26, 2014 | Kodak ESP 7250 All-in-One Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
Won't print black and white
This happend with some printer models that both cartirdge should be there for proper printing.in your case this may be due to that some printing you do may be in gray scale printing that type of printing use color cartridge for printing.thats why your color cartridge get consumed.so pls replace color cartridge or refiel it.
Aug 17, 2009 | Lexmark C530dn Laser Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
12 people viewed this question
k24674
jasbo
jasbo
