Question about Sony Cyber-shot DSC-T70 Digital Camera
I had dropped my camera on concrete, now the zoom is messed up....how can I fix the zoom?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 26, 2010
I dropped my 14-24mm F2.8 and now the zoom ring is jammed. Help !!
I've done the same thing before and the only advice I have to offer is to LIGHTLY, LIGHTLY tap around the lens (360 degrees) at the zoom ring with something like a Sharpie marker. If that doesn't work send it to Nikon. You spent a lot of money on this fine lens so if a "Quick Fix" doesn't do it don't mess around.
Good Luck, I feel your pain.
Feb 22, 2011 | Nikon 14mm F2.8 D-AF ED Lens
Hello. today i dropped my nikon coolpix L22 camera on concrete. and it was alright, but now it wont zoom in or out at all. can i fix it?
you will need to take it apart and check if any gears are broken or jammed. If gears are broken its a bigger problem in finding parts, if its jammed you might be lucky to release it carefully.
Jan 15, 2011 | Nikon Coolpix L22BLUE Digital Camera
Problem with zoom and touchscreen
there is two problum in your camera one is lcd defective & other is lsv assy so please go to youe nearst sony service centre & fix these two problums
Apr 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
After a drop lens is not closing properly, photos are dim
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon IXUS 80 IS Digital Camera
Constant under exposure.....
I can tell you what your problem is. You dropped it on concrete and you are suffering from impact damage. You have a whole bunch of internal damage to your camera, Don't worry, like anything, it can be fixed. Because it was dropped, its not covered under warranty. I have a friend who can fix it for you.
http://www.cameradr.com/
He is my friend, tell him Nate sent you.
Feb 01, 2009 | Nikon D40x Digital Camera
The lens retractor jammed after falling from bed
it can be fixed.... olympusamerica.com/repair
Dec 28, 2008 | Olympus FE-270 Digital Camera
Zoom lens broken nikon coolpix L1
hi
the lens alignment is messed up you can try to push it while slightly turning it or slap/tap the sides of the lens to fix it...
Aug 11, 2008 | Nikon COOLPIX P4 Digital Camera
Lens error 22
The camera can be fixed. The lens and any other parts will have to be replaced.
You should first get an estimate for service. It may be cheaper and better to replace the camera.
Jerry G.
Jul 30, 2008 | HP Photosmart M425 Digital Camera
Zoom Problem
The zoom are lock due to sudden dropped , the moving parts of the zoom dislocate or broken, the zoom malfunction,you try visit some camera juck shop or repair shop same brand to replce broken parts.
Dec 23, 2007 | Olympus FE-280 Digital Camera
Wont Focus
If its making a noise when you try to zoom in and out I would suspect physical damage. The more you mess with it the greater the chances of damaging it beyond economic repair. I would take it to the local authorized canon repair shop.
Jul 26, 2006 | Canon PowerShot S1 IS Digital Camera
Sony Cyber-shot DSC-T70 Digital Camera Logo
108 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
