Question about Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel
I've got a Kichler 900 watt low voltage 7.5 amp transformer. I want to run (4) 18.5 watt bulbs 400 feet away, so a total of 74 watts. I would come off the 15v tap, run the 400 feet and then split off (4) ways to the (4) post lamps. What size wire should be used for this 400 foot run?
  • temoesooman Apr 27, 2010
    Jeff,
    Thanks for your quick response. And thanks for your suggestion of going with 8 guage wire to cover future lamp installs. Can you tell me what wattage the 8 gauge would be vs. the 10 guage?
    How much more wattage do I gain going with 8 guage? Or if you can direct me to a Voltage Drop chart would be great as well.
    Thanks again for your help.
    Sincerely,
    Temoe
    Guru:
  • 1,051 Answers
You'll want to keep the resistance down as best as possible so I'd suggest 12 or 14 gauge wire. If this is an exterior application run everything above ground, connect lights and make sure there not dim. If they are you'll have to get special low impedence exterior wire.
Posted on Apr 27, 2010
  • 155 Answers
Good Day To You,
You will want to use at least a 10gauge wire for that long of run. It will give you 80 watts. However, I would consider even an 8gauge just because in the future you may want to add to it.
Thank You for using FixYa, please comment if you need any clarifications. Good Luck with your project, have a great week. Jeff
Posted on Apr 26, 2010
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
May 25, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
Does Malibu still make a model number ML500TW timer transformer
Intermatic/ Malibu series lights are available 44 watt, 88 watt, 100 watt, 121 watt, 200 watt, 300 watt, 600 watt, 900 watt.
None of the other brands sells 500 watt either.
Kichler sells 300 and 600 and 900Watts
Paradise does not have 500 watt
Malibu brand does not carry 500 watt
Portfolio does not carry 500 watt
Apr 16, 2013 | Hardware & Accessories
Just need help wiring up a transformer. 15PR200 SS
1) Copy following link for available resources for Kichler 15PR200 pro-series 200 watt transformer with selectable voltage output:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
2) Add comment and describe how many watts, and what gauge wire you are connecting to transformer.
Feb 09, 2013 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
Power into unit ok power comming out of unit is very dim.
If you have a volt meter, check the voltage, I believe it is supposed to be 12 volts.
Are your bulbs the proper voltage rating, that is 12 volts.
Do you have enough bulbs connected to the transformer, connected load should be close to 121 watts when you add up all your bulb wattages.
Don't confuse volts with watts. The transformer reduces voltage to 12 volts, but the wattage of the transformer is 121 watts. Each bulb must be 12 volts but wattage (brightness) can vary depending on the fixture from maybe 7 watts to over 50 watts.
Dec 01, 2010 | Intermatic Malibu 121W Power Pack...
Transformer problem
Malibu power pack has to match total watts of bulbs
15 bulbs each 20 watt = 300 Watt power pack
10 bulbs each 20 watt = 200 Watt power pack
Mar 01, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Malibu 300watts connected to 4/50-watts spot light and 5/7watts l
sir, you have a voltage drop problem. you make no mention of what wire size you are running to the fixtures or what the voltage is required. I need to know the wire size you have and the voltage required to run the lamps to come to any decision to repair your problem. write me back at tmierzwa@twcny.rr.com and we'll see what we can do.
Oct 24, 2009 | Intermatic 600 Watt Low Voltage...
Dim lites at end
You have a bad case of 'voltage drop my friend. Your transformer is probably undersized. Add up your bulbs and you have 234 watts. You're probably using a 200 watt x-former, right? Either lower the bulbs wattage to 11 watts, or get a 300 or 400 watt x-former.
Jun 20, 2009 | Intermatic Malibu 300W Power Pack...
My low voltage landscape lights are constantly going on and off once the timer activates them initially. I suspect there is a short somewhere, but is there a good way to locate the short besides pulling up...
Your transformer must have output greater of the total wattage required of the entire system. Example: Putting lights that draw a total of 250 watts with only a 180 watt transformer will result some lights not working, or dimming and flickering, or intermittent power outtages. I learned this from experience. Always go with a transformer that has more wattage available than what is needed. Also, using the incorrect gauge of wire can cause the same issue. Wire creates resistance. Distance the power must travel through the wire creates more resistance at the end of your run than the beginning.
Mar 29, 2009 | Garden
Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel Logo
52 people viewed this question
Top Kichler Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
