Question about Mitsubishi HS-U445 VHS VCR
E2 flashes and nothing works - Mitsubishi HS-U445 VHS VCR
  • Mitsubishi Master
  • 19,396 Answers
Hi.
E2 is not an error code, it is probably indicating the external line connected to the VHS.
Disconnect power for ten minutes, and check all wires connected to the unit. Reconnect the unit with no wire attached.
Connect SCART or AV connection to TV, then start first the VHS, and then the TV.
If that does not work, the unit must be disassembled and tested at component level by a technician.
In that case call Mitsubishi at the number listed on the owners manual.
See Mitsubishi Support.
Posted on Apr 26, 2010
The vcr has a flashing e2 on it and will not funtion ,it keeps cutting its self off.
E2 Is a code indicating that the tape chassis is locked in the eject position. You may want to have a look at the mechanism to be sure nothing has been bent or jammed - it should move freely when a tape is inserted.
You need to get this unit looked at by a professional. Get a "Quote" FIRST before allowing any repair work to be done.
May 01, 2011 | Televison & Video
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
I want to transfer the information from palm desktop on a PC to Mac OSX. The palm tungsten e2 is water damaged and not working.
Inside the PalmOne forlder in Program Files, find a folder that is named the same as you Hotsync ID. A flash drive would be the best idea to transfer the files over to the Mac. Some flash drives don't work on Macs, so try a few.
Jan 18, 2010 | Palm Tungsten E2 Handheld
Pentax espio60s?
E2 error code stands for an issue with the lens and/or shutter assy. unless you get the faulty parts repaired/replaced there is nothing you can do about it.
Sorry for the bad news.
Oct 19, 2008 | Photography
What does E2 mean when it appears on my PC720 Panasonic copier?
A E210 has to do with the scanner part of the copier. Is the lens moving OK on warm-up? Dose it move at all and what about the optic's do they move at all? I would need some more info on the problem.... I don't want to lead you on, that it is a easy fix... It is a fairly older copier.. It may not be worth repairing
Sep 09, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 printer all-in-one
goddman it same issue here - brand new, not working, drives me nuts - anyone solved this yet?
Feb 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Mitsubishi HS-U445 VHS VCR Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
