Question about Onkyo SKW-210 Subwoofer
The sound keeps cutting in and out. It appears that there maybe some kind of a short. How can I fix this problem?
  • 120 Answers
Posssible bad connections on the main board
and/or output IC intermittant!
Posted on Apr 26, 2010
Keeps cutting off when you hit the power button,it's like it is blowing a circuit or something,maybe a circuit protecter or a fuse> Thank you
Disconnect all of your Speaker leads and see if it still does that when Powering on, If not then one of your speakers/Wires has a direct short. you can test the speakers/Wires with a multi meter you can tell as they should have 6-16 ohm resistance. If it still does this with no speaker wires connected then you have an internal short and should take it to a repair center or local audio/video tech.
Jan 30, 2014 | Sony STR-DE525
ECI Fuse keeps blowing
What ever was blowing the fuse intermittently now has a full blow dead short. Trace it through to the unit and check for connections shorting out or the unit itself shorting out.
Jan 10, 2014 | Cars & Trucks
My harman kardon avr 100 keeps cutting out every 3 secs. i can hear the music but constently keeps cutting off. its very annoying... any ways to fix this probem?
Check the impedance of the speaker wires going into the amplifier. It sounds like at least one set of speakers is overloading the amp (shorted, or almost shorted)
Jul 24, 2011 | Harman Kardon AVR 100
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
Oct 31, 2009 | Car Audio & Video
Taillight fuse keeps blowing, replace bulbs, checked other fuses. plesase HELP!!!!!1
check the tail light assembly for corrosion.instead of a fuse alone,wire a 12 volt test light in series with the fuse.when a short appears say from a bad wire,the bulb in the test light will glow bright.there has to be a short somewhere ,maybe in the wiring.
Jul 13, 2009 | 1999 Chevrolet Silverado 1500
Kodak EasyShare Z700 Digital
you have a problem with your lens alignment try to turn it lightly and push it or tap it..
May 15, 2008 | Kodak EasyShare Z700 Digital Camera
Shutter will not close. Appears to be locked with shutter out. Slider is ok. Not batteries. Cannot take a photo. Nothing shows up on quick view. Red light blinks for a short time. Makes a beep sound....
it´s normal in that kind of cameras it can be fine but after u shoot one pic with flash will happen the same, to fix the problem u will need to send it to a repair centre, they will isolate some stuff inside to prevent that from happening.
Dec 27, 2006 | Olympus Camedia C-350 Digital Camera
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
Onkyo SKW-210 Subwoofer Logo
231 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
