Question about Dishwashers
Bosch Classixx dishwasher: Initially no water feed and 'water check' light came on. Removed side panel, emptied water from base. Ran OK for a week or so. The problem then repeated so side panel removed, float switch operation checked (OK) drained water from sump below polystyrene float. Ran OK but contents came out dirty and cold - no heat. Side panels off again, water in base but no obvious leak when watched during cycle - still no heat. Help please.
  • 1 more comment
  • sharpjohn Apr 26, 2010
    Where do I find the heater element so that I can check this out?
    Does this heater element heat both the wash water and drying cycle?
    Where is the water in the base coming from? No obvious leaks seen by looking under durting a cycle with the side panels removed.
  • sharpjohn Apr 27, 2010
    This dishwasher is only 4 years old so we were not expecting troubles like this so soon.
    The pointers to the repair manuals were most helpful and hopefully will lead me to resolving the issues.
    Thanks.
  • 12,061 Answers
Http://www.repairclinic.com/Dishwasher-Repair-Help
http://www.applianceaid.com/dishwash.html
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Above are the best DIY help troubleshooting links about.
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/dish/index.htm
Above, troubleshooting link. Below is a Service and repair manual, this is what us engineers use to troubleshoot and repair. it is VERY comprehensive
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
http://www.cteq.ca/Doc_texte/DishwasherTraining%20bosch.pdf
Above is the Bosch Training manual, this is what is used to train people how to Fix, the dishwasher. Download ALL Links etc. Just follow the troubleshooting procedures.
Select, and Copy/Paste, the address to the address bar, and get the manuals or information and "How To".
Posted on Apr 26, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the dishwasher is wont fill its water-inlet valve issue. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. If you have checked all these and still there is no heat then it means its due to the heating element going bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Apr 26, 2010
    If you
    have water leaks around the base of your dishwasher, you may be using a
    detergent that is causing too much suds. Cut back on the amount of detergent
    you use, and see if that makes a difference. Water that spills through the door
    vent is usually caused by improperly loading dishes. Leaks from the door itself
    may be caused by a faulty door gasket or door tightness adjustment. You should
    check the main tub seal, the door latch, the door gasket, the water-inlet
    valve, and the fill and drain hoses.
    Also make sure the dishwasher is sitting level (you can adjust the front feet
    up or down, and many units have some type of levelers at the rear). Water under
    the dishwasher may be originating from a leaky hose or loose hose connection.
    Remove the lower front panel, and check the hoses. The pump seal may be
    defective, too; replacing this is a job for an appliance repairperson. An older
    dishwasher may corrode at the bottom, but this is fairly uncommon. If this is
    the case with your dishwasher, it's time for a new one.
    Please do
    assistance.
    Thanks
    Rylee
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Washer does not fill with water
I checked the inlet solenoid valve to make sure it was receiving power, it was. I removed the left hand side panel of the machine. The labyrinth was blocked with crud as was the float switch assy,
Cleaned them out,with boiling hot water, it now works.
Jan 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
Top Dishwashers Experts
