Question about Sony VAIO VGN-FS640W Notebook
When i start my laptop, it always says to press F1 to contiune, it say system configuration data read error, then it ony it boot. please help me to solve the problem.
  • 221 Answers
It sounds like an error in the copy of the BIOS on the computer.
It can be downloaded and reinstalled. But if the idea makes you nervous, take it to a specialist.
The site where the BIOS is located:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FS640W
Posted on Apr 26, 2010
  • 157 Answers
Try upgrading the BIOS firmware. that should correct the issue.
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
An error occurred while attempting to read the boot configuration data
my 4211c wont boot up all it does is say press alt ctrl and del to start system but when you do that nothing happens
Jun 25, 2011 | Advent 4211c Notebook
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
Hello. Completely out of the blue, when I turned my laptop on it immediately went to a black screen that said "A disk read error occurred press Ctrl+Alt+Del to restart." But when I do it takes me...
When your system boots it looks for a startup file which is located on your hard drive to load your operating system. If your system doesn't find your hard drive it would post a disk read error message.
To be sure your HDD is detected by your system, you can go to your BIOS setting by pressing DEL or F1 or F2 or F12 it depends on your BIOS maker then try to see on your BIOS setting configuration if your HDD drive is detected or not.
Sometimes and always happens that we forget a media disc on our optical drive and since the default first boot device is the optical drive the system looks for a startup file on it and post a disk read error. So check if you leave any disc on your optical drive and remove it.
It is very safe to configure your BIOS setting to set the HDD as the first boot device in case we leave something on our optical drive most of the time.
Hope this helps.
May 27, 2011 | Computers & Internet
Hello,sorry my english is not good, i have a problem with my thinkcentre M52 . when i start the comp it writes enter system password.i press enter and it goes into the Bios,but i cant change anything into...
Someone has put a password on the BIOS - you must input it before entering the BIOS and the normal boot procedure. Because of the way IBM are build you can't reset the password by removing the battery, but only by performing a low level BIOS upgrade - which only a dealer can do. You will have to take it to one.
If you aren't the one that put that password and noone had access to it then the motherboard is dying - replace it before it's too late and all your data is lost.
Jan 30, 2011 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
I have a Gateway solo 9550 laptop. When I turn it on it says ERROR Invalid system configuration data- run configuration utility. What exactly is wrong? Windows boots up when I press f1. How do I stop this...
You usually gets this message when you leave the system unplugged for a long period of time. Whe the internal battery drained out the system loses the configuration data. Normally the internal battery will get recharged when you plug the power back. Just have to go into the BIOS and set the date back to the current date. In some case the internal battery needs to be replaced if no longer holds a charge.
Dec 18, 2010 | Gateway Computers & Internet
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
System configuration data read error
If the flash bios installation was stopped, you might have to do it from dos, otherwise, go ahead and press f2 and correct any obvious errors (ie floppy drive listed and not present)
Mar 19, 2009 | Computers & Internet
Sony VAIO VGN-FS640W Notebook Logo
157 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
