Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My hard drive got unplugged without being stopped and now keeps running into read errors
    Novelist:
  • 128 Answers
Hopefully, the read errors are not from physical damage.
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and both checkboxes,both 'fix file system errors', and "scan for and attempt recovery of bad sectors" then click ok, the computer will then tell you it will scan upon next reboot (which upon reboot will take about an hour). Now click the DEFRAG NOW button. then choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to format the hard drive and reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Posted on Apr 26, 2010
Testimonial: "I had tried those steps prior, still ran into an error, HDD Regenerator was able to reset the parameters and now Windows XP seems to be able to set up"
My USB 2 1TB got knocked over and now is making a clicking noise. It is connected to my DVR not my computer. The programs on it play and I can record new shows but it still makes this clicking noise. Any ideas?
Posted on May 02, 2011
I NEED A FREE RESTORE AND BOOT AND BACK UP PROGRAM THAT I CAN DOWNLOAD FOR FREE ONTO A USB
if it keeps losing this file it can be a read wright error with the hard drive. you may need a new hard drive.
Sep 29, 2013 | Toshiba Computers & Internet
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
"A disk read error occurred. Please click ctr +
You have as it states, a disc read error which means you have errors on the hard drive.
As soon as you get into your system run CHKDSK/F, that will attempt to restore the damaged files.
Make backups and look for a replacement hard drive.
Hope that helps.
Feb 16, 2011 | Acer Aspire One PC Notebook
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
NON DETECTION OF HARD DRIVE
I just responded to this. But I would also suggest that you check the memory on the laptop. It may be causing the Stop errors.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 01, 2008 | Toshiba Satellite M35X-S311 Notebook
Is it safe to keep data cable connected without power cable
It is perfectly safe to remove the power cable from a hard drive but leave the data cable connected. Make sure that whenever you want to connect or disconnect the power cable, your computer has been shut down first. You could do it with the computer powered on as well, but this would not be good practice and you may put errors on your drive.
Sep 26, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Installation
unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Nov 27, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
477 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
