Question about Toshiba Satellite 1805-S204 Notebook
Same toshiba Satellite will not flash problem,,,,,
DanserMax, Hi **** i've posted the information you asked for
hope the additional infos help
thankyou in advance.....
  • DanserMax Mar 30, 2008
    Thank you, for taking the time and interest in my problem Mike.
    But i am giving up on these 3 laptops yes 3 laptops from the same owner. I,ve aleady downloaded the 1183v21.exe file from the toshiba site and created the flash diskette but like i told you in the previous comment i am not able to flash the BIOS i tried to localise the Eprom to change/replace it but i cant find on the MOBO. My problem is when i put a new HD in one of these laptops the HD become "infected" and the laptop tells me he doesnt see the HD.
    And when i put one of the HD in an working withn no problem laptop i take out its original HD and put one of these in then the laptop become also infected (BIOS) and tell me it cannot find any HD. not even when i replace the original HD back in the laptop same story. So i "Fucked Up already 3 laptops i am giving up.
    Thank you for your assistance **** Doe
    DanserMax
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Thx for the reply. I think for the meantime we will stict with the BIOS upgrade first. When done then we can sheck out the HDD.
Have you tried the BIOS by Floppy sticking with Toshiba's utility.
The current BIOS v.1.10 is Initial BIOS for Satellite 1800, download ACPI Flash BIOS version 2.10 for Satellite 1800/1805-Sxx4 - http://cdgenp01.csd.toshiba.com/content/support/downloads/1183v21.exe from a Windows PC. Run "1183v21.exe" to extract the files to a folder. Check the readme file for installation info
****Extract from ReadMe File******
A DOS batch file, INSTINFO.BAT is provided in the ZIP archive which will create the BIOS installation diskette.
If all else fails, you can execute the self-extracting diskette image manually. This file is named 1349D21.EXE , and needs a parameter of A: (1349D21 A:) to successfully create the diskette in drive A:
Mike
Posted on Mar 27, 2008
SOURCE:
All I get is a flashing red light, please help
We cannot help you with more information as to at least the make and model of whatever it is you're asking about and what you weredoing when what ever light you're asking about started flashing. Please re-post your question with the additional info.
Mar 25, 2016 | Music
HOW DO I UNISTALL A PROGRAM IF IT WON'T LET ME ?
Offhand, a couple of ideas, queries and suggestions:
  • make sure your are logged in as administrator or run the uninstall as administrator (right click);
  • some programs has to be stopped prior to being uninstalled;
  • try doing the uninstall in Safe Mode.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 21, 2008 | Toshiba Satellite A135-S2276 Notebook
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
Toshiba dc connector
If the laptop still works, then there would be no need to replace the motherboard. The DC jack is replaceable/repairable. What would be more challenging is the disassembly and eventual exposing of the bottom part of the circuitry where the DC jack is soldered into. Often the DC jack would have at least 2 solder point (not more than 3). This might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Oct 25, 2008 | Toshiba Satellite (K000004080) Motherboard
SONY VAIO ASSEMBLY SHEET FOR PCG8M2R LAPTOP
For some Sony Vaio, pls try here or here.
Oct 24, 2008 | Toshiba Satellite A25-S207 Notebook
TOSHIBA A100 DRIVERS NEEDED
There are at least 85 different downloads for a Toshiba Satellite A100-S8111TD since the Operating System was not specified, pls start here.
Aug 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop
Appreciate the "Ask Me".
On your post, pls try:
  • click on Start, Control Panel, Network Connections;
  • right click on Local Area Connection;
  • click on Properties;
  • click on Configure Button;
  • click on Advanced tab;
  • highlight Connection Type, in the Value box, select Auto-Negotiation;
  • you may be asked to reboot.
You could also try the 100 Base Tx Full Duplex or the 100 Base Tx Half Duplex.
It would seem that the orange led indicates a 100mbps connection while the green is for 10mbps.
Aug 14, 2008 | Toshiba Satellite 1405-S151 Notebook
Processor??
While I would suggest additional memory (if PC is capable) rather than a change of processor, there are still a couple of actions that can be done to increase the efficiency of a PC. Please refer to this posting of a very similar concern.
Apr 25, 2008 | Toshiba Satellite U305-S7449 Notebook
I have purchased a wireless router and cannot find the icon on my laptop
In some Toshiba laptop, there is a small switch at the right hand side. If I remember right, it is a small blue button. It's pretty small. Alternately, some versions have it in front/right side.
Thank you for using FIXYA.
Feb 12, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
365 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
