Printer will not print, power is on
Printer will not print, power is o. Deleted spool a few times. Replaced black cartridge. Think the problem might be a low color cartridge even though I have it set to just use black cartridge. No flashing lights, Have powered doen printer and PC more than once.
  • limeken Apr 26, 2010
    I reloaded the drivers, the online light is on and it is my default. I am thinking the color cartridge might be low on ink but cannot find a way to check it. Don't wnat to buy a new one if not necessary but looks like Imight have to that route. Thanks for the response.
  • 157 Answers
Make sure you do not have a driver issue. Also make sure that the printer says its "online" and is set to the default printer.
Posted on Apr 26, 2010
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
I refilled my HP black ink cartridge and now when I try to print anything the printer starts to print about 1/3 of the page then it stops and waits 2 minutes then completes printing that page. Is this...
You can use refilled cartridges for your printer just make sure they are of good quality. You can only refill cartridges a few times before the printhead on the cartridge no longer works. The problem you are having does not have to do with the cartridge, it is probably an issue with the information being spooled from your computer to your printer. Depending on the amount of information on your document, the memory is hesitating before in can download more and continues to print.
May 31, 2010 | HP Photosmart Premium C309A All-In-One...
Cartridges replaced,not printing colors
Are you using compatible cartridges? If so have you used them before?
Make sure that you run a cleaning cycle in the printer and then print out a test sheet to see if there any issues. You may have to run the cleaning proces 2 or 3 times to get it working properly.
Sep 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Replaced Cartridge on hp 6213 message does not disappear
A few Trouble-shooting tips.
Switch off 5 mins and, reboot.
Remove and Re-insert, leave switched on for this. it's the correct way.
possibly hasn't connected with electrical contacts,
Delete/cancel spooled print jobs
Hope this helps
Regards
Apr 16, 2009 | HP Officejet 6200 All-In-One InkJet...
My problem is the same as that of miketheskibm. I
clear the printer rod and cartridges area.
and let me know.
Feb 19, 2009 | Lexmark JetPrinter Z22 Color InkJet
Not printing
First try a "hard restart", which simply means unplugging the power cord of the printer,then replugging it after a few seconds have passed. If that does not work, then rerun the CD used to install the printer.
Also, by typing " ONLINE LANGUAGE TRANSLATION" into the Google searchbox, you will have your choice of several websites which translate Spanish into English for free. PIck a website which translates whole paragraphs at a time, rather than a website which only translates a few words at a time. I have personally found that some websites are easier to use than others, so it pays to shop around.
Hope these suggestions help you out.
Jun 27, 2008 | HP PSC 1315 All-in-One Printer
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
The printer say there is no ribon but i put a new one and still it's not working
try to install again but this time make sure you follow the manual especially on step 5,6 and 7 I list down again the step from the manual 5: Load the new roll of print ribbon on the cartridge. ? Put the full spool of ribbon on the supply spindle of the ribbon cartridge. Push until the spool clicks onto the spindle. ? Put the empty take-up spool on the spindle with the solid black gear. Push until the spool clicks onto the spindle. 6: Replace the loaded ribbon cartridge in the printer. ? Make sure both spindles rest in the black supports on the left side of the printer. ? Make sure the ribbon cartridge handle rests in the supports on the right side of the printer. ? Make sure to install the full, new spool toward the card tray of the printer. 7 Close the printer cover. Press down firmly to latch it.
Aug 30, 2007 | Datacard SP35 Printer
27 people viewed this question
k24674
jasbo
jasbo
