Question about Canon imageRUNNER 600 Printer
My copies are too light - Canon imageRUNNER 600 Printer
    Guru:
  • 1,481 Answers
The cartridge inside is low on tonner
Posted on Apr 26, 2010
Will not copy from glass, displays Now copying page1/1.Will copy when sent from computer .This just started happening a day ago. please help I love this little printer
CHECK THE GLASS LIGHT IF ITS DEAD THERE WILL BE NO ILLUMINATION HENCE NO COPYING AND CHECK IF ITS SCANNING ACROSS THE GLASS LIKE A TRAVEL LIGHT IF NOT REPLACE LIGHT AND BELT OR TRAVEL LIGHT MOTOR
Oct 08, 2015 | HP OfficeJet 4620 All-in-One CZ152A
How to cut copy and paste
CTRL+V = paste
CTRL+X = Cut
CTRL+C = Copy
Sep 03, 2014 | Microsoft Computers & Internet
What is the remedy for this problem F5 ERROR CODE?
F5 Content Copy lamp lighting abnormality
Detail The copy lamp does not turn on.
Cause Copy lamp abnormality
Copy lamp harness abnormality
CCD PWB harness abnormality.
Check
and
remedy
Use SIM 5-3 to check the copy lamp
operations.
When the copy lamp lights up.
Check the harness and the connector between
the CCD unit and the MCU PWB.
When the copy lamp does not light up.
the copy lamp unit and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB. "
Jul 19, 2014 | Toshiba E-Studio 202S Digital Copier
Error code f5
Check
and
remedy
operations.
Feb 22, 2013 | Toshiba E-Studio 202S Digital Copier
Arm 205 display error F5 02 what this the solution for resetting ???/
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Dec 01, 2010 | Sharp AR 201 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
RICOH COPYING MACHINE MODEL 3713
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Aug 24, 2008 | Ricoh Office Equipment & Supplies
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Canon imageRUNNER 600 Printer Logo
80 people viewed this question
old marine
old marine
