Question about Samsung Digimax 101 Digital Camera
In the MODE position to review pictures,3rd selection, the screen is lite , but no images. can't turn off, must power off, remove batteries to clear....all else works. takes picture.
  • Samsung Master
  • 19,396 Answers
The wheel selector switch is probably defective.
Call Samsung at the number listed on the owners manual. They will confirm the diagnosis.
If the camera is less than one year old, it will be repaired at Samsung expenses.
If warranty is expired, get a quote on repair. You can also get a quote from a third party here:Advance Camera Repair
Posted on Apr 26, 2010
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
Horizontal lines on the screen after the picture is taken
Remove the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn on the Camera and reset it to the original factory settings by selecting the "Initialize" option under Setup1.
If the issue persists then service will be required.
Sep 08, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
SONY DSC-H3 File Error after taking pictures
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
if it doesnt help then my friend ur CCD imaging Device is Faulty
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Jan 27, 2009 | Sony Cybershot DSC-H3 Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
I can review, but not take pictures or video
Well, I have the same problem. Looks like the mighty SONY has created a turd and now I need to spend another 300 plus dollars for another one. Thanks Sony!
Oct 13, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
No images/picture:only right after turn on
Could be A. Battery contacts need a clean take them out and with the end of pencil eraser clean the contact in base of the chamber. B battery door losing tension - press it closed whilst in use. C. an internal connector worked loose try gently squeezing around the base of the screen- this usually where the connectors are. Do get onto Canon Tech Support Team. Just be prepared for a no repair solution. I.E. new camera
Jun 30, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Can I move images saved to the internal memory to the optional xD-Picture Card?
You sure can. Go to your shooting mode menu. Scroll down to BACKUP Click on OK Select YES Click on OK All image data stored in the internal memory is copied to the card. Press MENU to exit the menu. Make sure there is enough room on your card to hold all the pictures in memory. When you've copied to the card the original pictures are still held in the internal memory so you will have to clear it. When the card has insufficient memory, [CARD FULL] is displayed and copying is canceled. When the battery icon is blinking, pictures cannot be backed up because of insufficient battery power. If the battery power runs out during copying, the image data may be lost or damaged. I recommended you use the AC adapter if you have one. If not, make sure your batteries are charged. Never open the battery compartment/card cover, remove the batteries, or connect or disconnect the AC adapter during copying as this may cause malfunction to the internal memory or the card.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Samsung Digimax 101 Digital Camera Logo
19 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
