Question about Samsung Washing Machines
Packing and Shipping Samsung front load washer and dryer
We are moving and have been told need to install the shipping bolts on my samsung frontloader washer and dryer. We have the shipping bolts but is this something we can do ourselves or should we have a trained technician re-install them before transporting them?
SOURCE: shipping bolt installation
A total of four shipping bolts need to be installed: two longer ones on the bottom and two shorter ones on the top. Each shipping bolt consists of a metal screw inside a plastic cylinder which fits between the washer suspension and the back of the washer cabinet. The metal screw pulls the washer suspension against the plastic cylinder which, in turn, is pulled against the rear cabinet, thereby securing the suspension against the back of the cabinet. The Whirlpool part number is 285955. These bolts can be ordered from various suppliers for $20 - $30. To install these bolts, you will need a 13 mm wrench and a flashlight so you can see where the bolts screw into on the washer suspension.
The procedure is as follows:
1. On the back of the washer, remove the 4 plastic covers over the oblong shipping bolt holes. Carefully pack these covers with the water and drain hoses as they will be needed when the washer is re-installed in its new location.
2. Using the flashlight as a visual aid, look inside the oblong holes and identify the area on the washer suspension into which the shipping bolts screw. It is a white plastic part that is not directly behind the the shipping bolt holes, but is slightly above that level.
3.Look at the shipping bolts. The bolts described above (Part number 285955) have a a plastic arm at one end . This arm must be sawed-off for installation on older machines. You will have to determine whether or not the arm needs to be removed.
4. Starting with the bottom two holes, carefully slide a shipping bolt through the hole toward the front of the machine. Angle the bolt upward toward the screw mating hole, and carefully guide the bolt into the hole. Use the 13 mm wrench to engage the bolt into the mating hole.
5. Make sure that the plastic end of the bolt is closely seated against the back of the washer cabinet. Using the 13 mm wrench, screw in the lower two bolts, but do not tighten at this time.
6. Repeat steps 4 and 5 for the upper two shipping bolts.
7. After the plastic part of all 4 bolts has been firmly seated against the back of the washer cabinet, carefully tighten all 4 bolts.
8. Go to the front of the washer and push on the drum. The drum will rotate but it should not rock. If that is the case, then you are done.
Posted on Apr 28, 2008
  • 67 Answers
SOURCE: How to INSTALL the shipping or transport bolts prior to moving my washer?
there should be i think 3 holes in the back of the washer and u need i believe the orange shipping bolts and they screw into the back to hold the drum in place because if u move without the u have a very good chance of breaking the shocks which there are 4 and they are about 30 dollars each plus the price of labor of installing new ones and there not very easy to get to.
Posted on Mar 20, 2007
SOURCE: Shipping bolts for Maytag Neptune
There is a product call LITKIT TM, it is a universal shipping kit for washing machines. www.litco.com
Posted on Jun 11, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore front loader run with shipping bolts in
I would have sears replace the washer and also replace all the damage in your house. If it pulled out the drain hose there could be damage in there, if they are not willing to replace the machine then they should run a thorough diagnostic to make sure EVERYTHING is in working order, and still replace what is damaged to your house
Posted on Feb 09, 2009
  • 57 Answers
SOURCE: missing shipping bolts
if you are moving and you are using a dolly to move it than you dont need shipping bolts. i del. preowned washers and dryers everyday and never put shipping bolts back in just becareful and use your head and you will not hurt anything.dont bounce it down stairs either it is a 2 person job so dont forget to get some help
Posted on Feb 25, 2009
If a front load washer is being shipped with only 3 shipping bolts ( from korea to USA),would the washer be OK or there could be possible damage to the drum/washer in anyway?
3 bolts will be ok, The drum cannot move and as long as the other 3 bolts are intact and not broken then there won't be any damage to the machine.
May 02, 2017 | Samsung WF431ABPXAA Washer
My Frigidaire Affinity dryer has started vibrating more and more during operation. Is the motor going bad or is there another problem?
Hi
Try the following to reduce the noise--
Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor.
• Shipping bolts and foam blocks have not been removed during installation. Check out the installation instructions for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please post back for any further assistance.
Daniel
Jul 24, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Shipping bolts were not left when machine set up. moving from virginia to Arizona. Where can I buy replacement shipping bolts
If you can remove the top cover, then all you need to do fit some polystyrene packing or the like inside the cabinet to stop the drum from moving about, and this should do the trick.
Jun 16, 2010 | LG WM-2077C Front Load Washer
Does a Maytag Neptune MAH6500WH have retaining bolts or pins that need to be installed before it can be moved?
If you are moving the washer for a long distance move, it is recommended that the shipping bolts be reinstalled to help prevent damage to the drum and suspension mechanism. This would be especially important if you're using a professional moving company, as they won't be able to move/load/unload it without problems.
If the move is relatively short and won't experience alot of aggressive movement, you can likely move the washer without chance of damage - provided you are careful and don't bounce the washer around.
Here's the info from the Maytag website, regarding moving front loading appliances:
If you are moving to a new home and plan to take your front-load washer and dryer pair with you, please call 800-688-9900, and speak to a fabric care expert. Our expert can recommend a Maytag-authorized servicer who will reinstall new shipping bolts to your washer.
New shipping bolts must be reinstalled to avoid internal suspension and structural damage to your washer during transport.
OK, so get your model number handy and give them a call, (you're missing some digits/alphas) you can get an online copy of your owner's manual that will show you the part numbers for the shipping bolts, if you've misplaced them, or give a call to the toll free number for Maytag, and they'll provide you with the part numbers needed so you can order them yourself and likely save some money versus having a service tech some out and do it for you/
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Hope you find this very helpful and best regards!
Aug 18, 2009 | Maytag Neptune Washer
Missing shipping bolts
Jan 30, 2009 | LG WM-2077C Front Load Washer
The machine rocks so bad my wife had to turn it off
When I went to buy mine I asked about the bouncing and shaking and he said alot of times people do not take the nuts and bolts off the back that allows the drum to move properly causing it to move etc. There is a pic on the back that shows you were to remove them.
May 11, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
565 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
