Question about Maytag Neptune MAH5500B Front Load Washer
The rubber skirt outside of the drum has ripped
The Rubber skirt outside of the clothing drum has ripped and water is leaking out of it. Where can I get a replacement skirt and is it something and average joe can replace themselves?
  • Maytag Master
  • 19,396 Answers
Hi.
To find parts you can use the links listed here: Parts and diagrams.
Regards.
Posted on Apr 26, 2010
Next question, how do I get the slime out of the clothes from washer?
Cleaning the rubber door gasket will not get rid of the slime issue. The slime comes from buildup on the outside of the washer drum. There are two causes for this. First, if you always close the washer door after use, then the moisture inside the drum cannot dissipate and the slime can form. Also, using the wrong type of detergent (or an excessive amount of the correct detergent) can cause the slime. There are front load washer cleaning products that you can purchase and run to clean the slime from the outside of the drum.
Dec 15, 2014 | Washing Machines
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
Drum came out of rubber skirt around door
Check that it is not ripped
Take the power off
Take the top off
Refit the gasket witha new clip
Dec 06, 2009 | GE WSXH208A Front Load Washer
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
How to fit a drum rubber on a wf000
disconnect from mains. remove top
undo clamp that holds gasket to cabinet and peel away from cabinet.
there is a clamp holding rubber to tub - usually like a giant hose clip.
undo this clamp and peel rubber away from tub.
lubricate the slot in the rubber that goes on to the rim of the tub with washing up fluid
starting at the top, insert slot in rubber onto rim of tub.
work you way round in both directions pushing the slot onto the rim. this is a knack and you will have to be patient.
when completely on, refit clamp.
on outside, fit rubber onto cabinet (this is easy) and refit outer clamp.
test for leaks on rinse as water level is higher.
water will be foamy till washing up fluid washes away
Sep 29, 2008 | Hotpoint Washing Machines
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
163 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
