Question about Maxtor Hard Drive
Massage appear no hardisk found
When start pc message appear no hard drive found
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    Turn off your PC. Isolate from electrical outlet and ground yourself. Check the hard disk connections. remove and reattach the jacks.
  • Robert Birdsall
    Robert Birdsall May 11, 2010
    you want to make sure that both the power supply and the data cable to it are plugged in and receiving juice do you hear the hd whine after startup or is it doing nothing at all?
    Scholar:
  • 75 Answers
Try the following: 1. Try replacing the IDE cable or SATA cable of your hard disk. 2. Check the power cord if it is properly seated at the hard disk. 3. If you are using IDE hard drive. Check master or slave setting. 4. If you added a cd/dvd rom make sure it is set to a slave. 5. Try replacing another hard drive. Check if it works.
Thanks. More Power. Please rate. Let me know if you need further assistance.
Posted on Apr 26, 2010
  • 1,183 Answers
Shutdown the system and remove all power from the computer. You might need to reseat the hardrive as it it might have come loose.
Then power it back on to try again.
Thanks for using Fixya
Proton
Diskettedrive 1 seek failure primary hard disk drive 1 not found secondary hardisk drive 1 not found cp says strike f1 but cp boot only up to xp logo then re start again and so on again and again
If both of the hard drives are on the same data cable/disk drive controller it is unlikely that both the have failed. Reseat the data cable connectors on the hard drives and at the motherboard.
Reboot you computer and hopefully it will boot up.
Check the BIOS configuration to see if the BIOS detects the hard drives.
If not the disk drive controller on the motherboard may be faulty.
Aug 26, 2011 | Dell OptiPlex GX150 PC Desktop
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
My laptop says that the operating system is not found. I also here clicking near the hard drive when I start it up. Help!
GOTO BIOS
CHECK IF HDD IS DETECTING OR NOT
IF IT IS NOT THEN
REPLACE DATA CABLE
CHECK FOR POWER OF HDD I.E. POWER CONNECTIVITY PINS
IT WILL BE DONE
Feb 05, 2011 | Computers & Internet
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
When i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Jan 08, 2010 | Dell OptiPlex GX150 PC Desktop
Restart problem
Your 2nd hard drive is failing. Until you repair or replace it this message will continue to appear.
Oct 30, 2009 | Toshiba MK2035GSS 200 GB SATA Hard Drive
Hard drives not detected in my hp compaq nx6310....
Dear, in all the new laptop's its common problem because what bootable cd u are using did not contain sata drivers and thats why it shows no harddrive found ok so search the sata drivers and make bootable cd by adding this sata drivers and than try to boot.
Jan 19, 2009 | HP Nx6310 Notebook
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Oct 19, 2007 | Seagate Barracuda 7200.7 200 GB Hard Drive
Maxtor Hard Drive Logo
137 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
