Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Timer not working?
I have placed red and black pins in proper position. Followed directions exactly. The dial inside is turning but is not tripping the lights on or off? Is the inside dial supposed to rotate counterclockwise when running? When I turn on manually works no problem?
  • 110 Answers
Look closer at those pins as the motor turns those pins turn a togle switch on and off make sure those pins are able to togle that switch you will see that switch under the that timer disk
Posted on Apr 26, 2010
I have an intermatic timer for my outdoor lamp post, but I'm having a problem getting it to turn off automatically. The clock dial works fine, the manual on/off works fine and the automatic "on" works...
try manually pushing lever as if you where the pin with a screw driver. maybe the pin needs to be mounted farther toward the edge of the disk to trip the switch completely?
Nov 04, 2013 | Intermatic Hardware & Accessories
I need instructions for indoor timer model TM-023
This type of timer has removeable pins in two colors. The difference in color is so you can set two different start and stop times and tell which is which. Use both white pins for the first time period and the other color for the second time period.
You will notice that the pins have a short leg and a long leg. The long leg is the one that trips the switch on and off. The pin that has the long leg positioned to the outside of the dial will turn the switch on. To turn the switch off, you need the other pin to be turned so the long leg is toward the inside of the dial. Repeat for the other set of pins.
You must also set the current time of day and that is done by turning the whole dial so that the small arrow is pointing to the correct time of day, either AM or PM. Now just plug the unit into the wall and plug in the lamp or whatever into the unit. It will come on and off at the times set by the pins.
You will also notice that there is a manual on/off switch on the timer as well. This is so you can turn the lamp on or off manually. If you have turned the lamp on manually and the timer gets to the time when it would normally come on, nothing will happen because it is already on, but if it gets to the time when it is set to turn off, it will automatically turn off even though you turned it on manually; and vice-versa.
I wrote these directions because I couldn't find directions anywhere online for this type of timer with the removeable pins. I hope this is clear for you. It is a nice timer once you figure it out. :D
May 03, 2012 | Kitchen Appliances - Others
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
My tork 1101 timer will not trip on. It trips off ok. Manual override works fine, trip pins fine. When I manually rotate the dial it trips off fine, i hear and feel it click when the on pin pass, but the...
as per geno, Tork T1101 has 120 Volt clock motor and is generally used for 120Volt loads but can be wired other ways to handle 240Volt circuits.
Here are basic wiring instructions for 120Volt.
1) Black Hot wire from breaker connects to both terminal 1 and terminal L.
There is usually a brass connector plate between these two terminals. If that plate is present, then connect Hot wire to one terminal or the other.
2) White Neutral wire from breaker box connects to terminal X.
3) Black wire going to Load (light, fan, motor) connects to terminal 2
4) White neutral wire going to Load connects to terminal X along with other neutral wire.
That's the wiring.
To operate timer:
1) Set current time: rotate dial clockwise until current time lines up with the word TIME that is located to lower right of dial at about 5 o'clock position.
2) Put on-off trippers on outer edge of dial at times you want timer to turn on and off.
The trippers are marked ON and OFF.
3) The ON tripper rotates around on the dial until it encounters a lever, and then it pushes the lever.
The lever clicks one direction for ON tripper, and then OFF tripper pushes lever other direction.
The lever opens and closes electrical contacts which turns the Load on-and-off.
May 14, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Which way do the pins need to be positioned on a manual timer for it to be on, ie is it up or down for `on`
You posted under GE 15004 timer.
Push trippers down and then rotate tripper around dial to desired on or off time.
Release tripper and it tripper locks upward in place.
Other timers have segments and pins that are located around timer dial
The position for ON-OFF varies by brand and model number.
I suggest you turn lamp ON and make sure bulb is good, plug lamp into timer, set a few pins one direction or other, plug timer into wall. Manually rotate timer dial clockwise, and watch lamp turn ON-OFF to know how to set pins.
Also move the slide switch one direction and then other direction to see how override switch operates.
After checking operation, set pins exactly how you want, and then rotate dial clockwise until current time lines up with pointer located on inner dial.
Dial rotates with passing time and pins push small lever that opens and closes circuit.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
I get lights when I turn the switch to on but as the timer advances, it doesn't trip and turn the timer on
You posted under Intermatic T101 timer.
Add a comment if timer is different.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
1) If this is new timer installation, it sounds like black wires on terminals 1 and 2 are reversed.
Other cause could be the ON-OFF trippers not positioned on timer dial
2) If this is old timer that worked before, then tripper pins could be worn down.
Buy new trippers for T101 at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Nov 17, 2010 | RTO Intermatic T101M Timer Mechanism Only...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Can't seem to figure it out. Directions are not specific enough. We set "the time now", but the white/AM, dark/PM is weird. Please help w/ directions. We need the light for chicken house. Light on 5:00 AM...
What kind of Woods timer do you have?
Is the dial turning? The dial is the clock. And the clock needs electricity to work, just like alarm clock. If dial is not turning, the wiring is not right.
Does the manual override turn on the lights? Maybe the slider switch set to OFF? Set slider to "Timer" for timer functions to work.
Wall timer:
If you have 59017 wall timer, it has dark PM white AM. You rotate dial until correct time lines up with little triangle located on right side of center knob.
There are 48 plastic pins on dial ... when pins are moved out, the lights are off. For timer functions, set slide switch to 'Timer'
Correct wiring is needed for timer to work:
Timer black attaches to Hot wire from breaker box
Timer red attaches to wire going to Load (lights)
Timer white must attach to white Neutral (or if your box has no neutral, connect white to bare ground)
Timer green connects to bare ground
If wiring seems right but dial on front of timer is still not rotating, then reverse Timer red and Timer black and see if that sorts out problem.
If this is wrong Woods timer, please re-post question.
Oct 02, 2010 | Woods Hardware & Accessories
Timer stops at on postion? transfomer works, have to do it by hand
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
May 04, 2010 | Intermatic Malibu 300W Power Pack...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
217 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
